ignition switch connector
Will the connector off of a 67-72 C10 fit the ignition plug for a 60-66? the connector looks the same, i just want to make sure before i buy one. I tried looking for a connector for my '65, but nothing was coming up.
Re: ignition switch connector
try www.repairconnector.com.
I looked there and their listing is '67-'93 for dash mounted ignitio switches. Good picture of it, too, looks quite different. If your housing is good, they have the correct replacement terminals, that work in the housing. I'd double check with them, they have alot of hard to find pieces and the prices are reasonable. Last edited by tincan1966; 05-07-2013 at 11:49 AM. Reason: added info |
yea thats what im looking for. I already bought a new lock cylinder and am about to buy a new ignition switch, i just wanted to make sure the plug for 67 and up is the same as 60-66. It looks like it is.
Doesn't look to me like they'd interchange
Switch on left is a '64-66.
switch on right is a '67-72 |
Ah, ok i see now :-(
I see what your saying about my plug being in good condition, just replacing the termnials and wires. I may have to go that route.
![]() Join Date: Aug 2008
I don't know of anyone that reproduces that plug. So i always save old wiring harnesses that i find si that i can have the right connectors when i need them. However I recently discovered that the early 60s impala switches have the same pinout. Perhaps there is an ignition switch connector marketed for the impalas? Just a thought.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Did you ever find the right pigtail? I'm trying to find one for my 66. What if I just switched out the ignition switch for a 67 and bought that pigtail?
Posted via Mobile Device |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You might want to verify that a '67 ignition switch will fit the '64-'66 dash hole. If you have the correct plug for your '66 ignition switch all you need is the Packard 56 style wire connectors. Those can be found at NAPA but they are stupid expensive there last time I had to buy some. Here is one of several listings on ebay.
http://www.ebay.com/itm/25-Packard-5...6a8df2&vxp=mtr
I just bought some packard 56s (female) at $1.00 EACH OUCH
60-66 Nut
The last time I bought some at a local NAPA they were over $2.00 each.....might I emphasize the last time
