Old 05-07-2013, 09:53 AM   #1
RenoKeene
Florida Edition
RenoKeene's Avatar
Need rearend compatibility info
Having trouble finding a local 12 bolt leaf rear for our next 70 GMC build..
I know the width got wider after 70, my concern is saddle and shock mount bracket locations. My question is are any later model rears with brackets in the same locations?
I found a 74 Blazer and a 78 1/2 ton 4x4 in a junk yard but can't get under them to measure.
Any info will help.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-07-2013, 09:29 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Need rearend compatibility info
Anybody? Really don't want to have to take a shovel to the yard.....but I can if I have to.
Old 05-08-2013, 03:26 AM   #3
andrewmp6
If i remember right the 73-87 rear end is 64 and 1/2 inches wide,And yours is 57 inches wide.As far as the brackets in the same place i have no idea on those.
andrewmp6 is offline   Reply With Quote
Old 05-12-2013, 07:21 AM   #4
wraprail
wraprail's Avatar
Seven and a half inches wider?
Really?
wraprail is offline   Reply With Quote
Old 05-12-2013, 10:40 AM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
I believe the 71-72 rears are 59" back plate to back plate. Someone can jump in and correct me if I'm wrong. Later models should be similar I think.
Very surprise no one has answered this yet, maybe I posted this in the wrong spot?
Old 05-12-2013, 11:56 AM   #6
oldman3
oldman3's Avatar
I did a search on site once along time ago and this is what I got back. Not sure if it is
100% correct, but I think it is very close.
67-69 mounting flange to mounting flange = 60"
70-72 mounting flange to mounting flange = 62"
73-87 mounting flange to mounting flange = 63.5"
In parts catalog new 5 lug axle for 63-69 are 30-3/4" long and the 70 5 lug axle is 31-1/2". Doing the math this doesn't add up right for flange to flange, but that's what it shows. Working on a 68 SWB now, that the owner installed a 10 bolt 81 axle and it is 63.5" flange to flange. Hope this doesn't muddy up the water to much....Jim
oldman3 is offline   Reply With Quote
Old 05-12-2013, 12:41 PM   #7
oldman3
oldman3's Avatar
check this thread out it has some good info...Jim http://67-72chevytrucks.com/vboard/s...d.php?t=551752
Old 05-12-2013, 09:49 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
Thanks Jim, good info.
