Straight axle
Hello all,
I have a decision to make; and I want to know your guy's opinion before I do anything serious. The picture below is what I found my brakes to look like. I don't want to buy new cylinders at $70 a side. My solution there is get a cylinder off of a newer 70's pickup which brand new, costs $13 a side. But I would need to drill new holes in each back plate just to mount them. BUT I was cruisin and perusin craigslist, and found this set up: http://chicago.craigslist.org/sox/pts/3771652867.html And it'd be great if it weren't for the fact it's a 57 1/2 axle, and I have a 52 1 ton frame. So my question is: Is it possible to swap this one in for mine? Either just to the kingpins or the whole axle. Thanks |
Re: Straight axle
My 50 was updated to 52 and newer backing plates, wheel cyls and shoes for the same reason. I would do that again or put your negotiating hat on and grab that axle.
Re: Straight axle
Cool
I'll go for the axle in a heartbeat, but is it worth my while? or am I going to need to find a way to graft it to the frame? |
Re: Straight axle
Look for 1 ton to 1/2 ton straight axle conversion threads. I am sure it could be done with a different hanger and shackle set up.
Hollister Road Co.
Re: Straight axle
The two axles are not interchangeable. One is from a taper frame truck and the other is a straight frame truck (55-57).
Re: Straight axle
Thank you both for the advise.
Actually, I went to sid's website. AD trucks have the same kingpin width at 50.5" The spring perches may different, but that's not too much of a big deal. The problem is TF trucks have a kingpin width of 54" and the kingpin size is a 1/10" bigger on my truck, so I can't just switch out the hubs. BUT I talked the seller. He said he just used a disc conversion kit. So I think I'll pass, and eventually make my own |
Re: Straight axle
Do you have any friends at a machine shop? I bought brass bushings and had them installed in my cylinders. No troubles so far, and that was in 94 or 95.
Drilling the backing plate holes for later cylinders doesn't sound like too difficult a job... |
Re: Straight axle
We have a machine shop at our school that I can use.
I was getting ready to do that, but it doesn't look like there is enough material to safely hold the cylinder in place. I'll weld in a support plate later on. |
![]() Join Date: May 2011
Re: Straight axle
Why not take the cylinders apart, see just how bad they are, possibly with your skills at your schools machine shop, bore the cylinders out to the next size and put new guts in the wheel cylinders. Who knows, you may be able to hone these out and put new guts in them. Once you have the wheel cylinders working, the rest should fall into place. Then later on you can think about what upgrade you may do. You have plenty to do in the meantime~
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
Re: Straight axle
I'll post a picture when I get home.
All that's left of the cylinder is the metal case. There's something I left out.... I actually kinda already bought the cylinders, and got one of them installed. |
Re: Straight axle
I didn't think I'd ever use ROTFLMAO!
![]() I've recovered now ![]() ![]() Posted via Mobile Device
Re: Straight axle
Let me get this straight. Is the rubber band there to hold the shoes up while servicing or did someone use that for a return spring.
#13 |
Re: Straight axle
First off, here's that picture I promised.
Both of the front drums look like this. I think the rear ones are still intact. Ret, I don't know. Those were actually zip ties. So my creative imagination came up with an explanation. Tell me what you guys think. Here it goes: So this one of the previous owners just had the truck painted a shiny red. (someone did a crap paint job) But he didn't want to ruin it by running it into a tree or something. So he decided to do a brake job in a field. (I found it on a farm) He dropped the springs, the wheel cylinder kit and screws in the field while doing it. BUT It started raining... so He threw a ziptie around the brakes so the wheels wouldn't lock up when he tried to wheel it into the barn. (I found this out the hard way) The next day, when he tried to finish the job, he lost all the parts. Last edited by mechanixman; 05-08-2013 at 05:08 PM. |
#14 |
Re: Straight axle
^ Sorry sir but that is a funny story
#15 |
Re: Straight axle
Ha ha I tried my best.
#16 |
Re: Straight axle
Dang, even the rebuild kits for those Huck wheel cylinders are 24.25 each at Chevs of the 40's and I didn't look further.
I'm a bit spooked on your mix and match brake setup though as I don't know how well it is going to work plus you won't have a way to adjust the brakes with the hub and drum on the truck. The simple solution would have been to install Bendex brakes off a 52, 53 or 52 and get rid of the Huck brakes. For probably the same cost you could buy the axle off craigslist and swap spindles and brakes to your axle with a bit of bushing finagling. Then the whole brake setup might go right on your spindles.
#17 |
Re: Straight axle
If you are talking about these,
http://www.bendixcatalog.com/Applica...ne=-%20All%20- That's exactly what I have I'll post some pictures of it installed next time I get a chance to pull the drum. |
#18 | |
Re: Straight axle
I'd try to clean it up for the heck of it. You're a machinist, put it on a lathe take a millionth off, hone it the hell out of it. Don't install the new ones until you're sure you cannot absolutely salvage these. My father could/would make anything work. At least give it a try
![]() Quote:
#19 |
Re: Straight axle
Ha ha, I'll see what I can do
#20 |
Re: Straight axle
Make me proud Nick! You can do this!
#21 |
Re: Straight axle
I got the master cylinder cap off (after 5 hours of a pair of vise grips, bruised knuckles, and a couple swears). And poured brake fluid in. I pumped the brake, and it looked like everything went down the line like it should have. A little while later, I looked under the truck, and I saw a little drip. But I think that's all from not having a steady hand while pouring.
#22 |
![]() Join Date: Oct 2007
Re: Straight axle
check out lmc they sell new wheel cyclinders for around 40 to 60 bucks for the 3/4 ton trucks. page 93. hope this helps.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
#23 |
Re: Straight axle
Nick, Here is my advice. The most important thing on this project is proper, reliable brakes. All the other things you are doing is second. Spend the money on your brakes. Jim Carter has wheel cylinder repair kits for 1 ton (1.375" dia) for $15 (ME338) or new wheel cylinders for $49.50 front (ME131) and rears for $69 (ME773). Please don't skimp on the brakes. This is for your own safety and the others on the road.
#24 |
![]() Join Date: Aug 2010
Re: Straight axle
You know the old saying 'Penny wise, pound foolish.'
Upgrade the brakes ! BTW 90's Isuzu cab over has the same width axles with disc brakes.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#25 |
Re: Straight axle
Coralhead, I hear ya.
Glen thanks for the tip! Now where am I going to find an Isuzu cab over?? ![]() We've got a bunch of friends that need their cars worked on. everything from new brake lines, to new alternators. I just want to get the drums working, so I can park it in the street while I take care of these. Unlike the go kart I built before this, Safety is my number 1 concern. I'm definitely going to put discs on before I get it registered. I figure if I don't trust the single master cylinder, why would I trust the stock brake cylinders? |
