1954 3100, Help me decide between factory frame w/IFS & 4 link or S10 swap
I am getting ready to start my 54 3100 project and i am really torn between keeping the factory frame and adding a IFS front and 4 link rear to it or doing the S10 frame swap. I plan to bag it either way so either frame will require c-notched in the rear. I plan to use a LS1 engine and automatic transmission out of a 2000 trans am if that makes any difference. I am not concerned about the dollars involved i am just wanting to know the pro/con of going either way and which would be the more straight forward and or easiest to do. Thanks
Re: 1954 3100, Help me decide between factory frame w/IFS & 4 link or S10 swap
S-10 swap is more of a budget choice imo. Front track width is narrow and rear axle must be changed anyways. Its a great way to go if you are on a budget.
If cost isnt the primary consideration, ifs on a stock frame is a better setup.
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
The s10 is cheaper but it also requires more fabrication work to mount the body. The stock frame is easier to throw a 4 link and IFS at but those parts are more spendy. I personally am staying with an original frame.
>>>>>>>> x 2 <<<<<<<
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
A
I"am also doing 54 3100 pickup I used the Heidts IFS and Nolimit fat bar Four-link and a LS3 engine check to make sure you have room for your header the frame rail is tight if you have AC you will have to relocate the AC compressor
Suburban Hick
![]() Join Date: Aug 2008
I'm doing an s10 swap personally. Mainly because, like stated above, I'm on a budget and the original frame was already hacked up. I also liked the fact that I can use the motor, tranny, a/c, and a lot of other parts from the s10. I just want to get the truck on the road so I decided the v6 was plenty of power for me.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
![]() Join Date: Aug 2012
I'm a fan of the stack frame with IFS, if budget allows of course. I've seen so many S10 swaps where the front wheels are way too close together. It looks weird.
Posted via Mobile Device |
I did a stock frame with IFS and 4 link.The IFS I did was a breaze to install, easier than bagging an s10 (to lay right) I've bagged 5 s10's. As far as the rear goes the advantage of a s10 would be the bolt on stuff if that's the route your more comfortable with. S10 would be cheaper if done frugally and you build your own body mounts. If not then it'll be close to the same imo.
Here's a link to my build http://67-72chevytrucks.com/vboard/s...d.php?t=553572 Posted via Mobile Device |
if Dollars are not a concern, order up a frame with the suspension you want, the way you want.?
ready to mount your cab on. |
