Old 06-24-2003, 02:49 AM   #1
Chevy Punk
Red Hot Headers
I just got my new 350 running in my truck and had it running at idle for about 10 minutes and the header tubes were glowing red hot. What could be causing this?
Chevy Punk is offline   Reply With Quote
Old 06-24-2003, 03:12 AM   #2
chevy55
Check your timing
1955 Chevy Shortbed Stepside 2nd Series.
http://community.webshots.com/user/chevy55truck
chevy55 is offline   Reply With Quote
Old 06-24-2003, 03:12 AM   #3
lpaine
lpaine's Avatar
I've never seen that before! Sounds scary-could be your fuel mixture on the carb is way too lean, I'm guessing here, is it a new or rebuilt carb? I can't think what else it might be........
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 06-24-2003, 03:15 AM   #4
chevy55
When I first got my 350 running I had this same problem. It had to do with two thing, timing and carburetion.
I've heard of it happening more often than you think.
Good Luck
Old 06-24-2003, 05:17 AM   #5
ZOOMY
RED HOT
A very fast idle 2K -3K and a slightly rich mixture will cause it.
ZOOMY is offline   Reply With Quote
Old 06-24-2003, 05:53 AM   #6
SEVEND2
SEVEND2's Avatar
safety tip, check your fuel lines between your cab and fuel pump make sure tey aint touching those red hot Headers
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 06-24-2003, 05:58 AM   #7
69 Short Fleet
I would definitely check your ignition system out!!! I rebuilt a 4 stroke dirt bike a few years ago for a friend and it did the same thing with the headpipe (bright orange) if that all checks out I would be interested to know whats up??? Best of luck, Doug
69 Short Fleet is offline   Reply With Quote
Old 06-24-2003, 07:40 AM   #8
Blazer1970
Blazer1970's Avatar
Lean or late is the rule for glowing headers. You either have a big vacuum leak causing the engine to run very lean, or your timing is retarded too much.
Blazer1970 is offline   Reply With Quote
Old 06-24-2003, 08:19 AM   #9
RED71CHEVY
RED71CHEVY's Avatar
yes, Bazer1970 is correct, along with the 2-3krpm cam break in
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
