Hotrodchevy
question about power brake booster
my question is what would it take to swap my non power brake 71 c10 to power brakes i have a 98 c2500 chevy parts truck that i would like to use power booster and brake reservoir off of what would it take to do this
2017 1500 CREW CAB GMC 1997 C1500 Chevy 1971 CHEVY CHEVELLE SS 402BB : 1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816 My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650 |
Hotrodchevy
Re: question about power brake booster
ttt
Hotrodchevy
any input
You need to run the booster hose to the back of the intake. Give me a second. I will post the part number.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#5 | |
You can see me holding the nipple in this video:
http://m.youtube.com/#/watch?feature=plcp&v=MIEkT-fKsOo Posted via Mobile Device
#7 | |||
To the OP, I am guessing you want to use the late model master as well? If so you will need to adapt the hard line fittings at the master? Do you currenty have disc brakes?
Well, I assumed he had swapped discs in, lines, booster, etc.
Hotrodchevy
the 71 truck came 5 lug disc brake factory but no power booster i plan on putting a 98 vortec motor in it out of the 98 c2500 but i also wanted to use the master and power brake booster off of the 98 as well and wanted to know what it would take to make it work on the fire wall to hooking it in to the brake line and i guess i should also asked dose a factory 71 with power brakes have bigger size brake lines then a non power brake truck
