Old 05-07-2013, 09:35 PM   #1
Dale99
shifter/driveshaft question
1. I got my np205 installed. But when I went for a test drive, I noticed my shifter was hitting the trans hump. My shifter is from a 73-75. Am I suspecting that I didnt research enough and that 67-72 vs 73-75 are shaped/bent differently?
2. If I twin stick this, can I do that w/o changing the shift rods?
3. On the front driveshaft. What is the name of that double joint up at the top? Mine is ratting and needs rebuilt/replaced.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 05-07-2013, 10:22 PM   #2
Redcap
Re: shifter/driveshaft question
2: You need to pull the shift rods to modify them.
3: Double cardan joint.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 05-08-2013, 09:05 AM   #3
Dale99
thank you!!
