Old 06-24-2003, 04:28 AM   #1
TIMSPEED
TIMSPEED's Avatar
Airbags + Drag Racing = Busted Bags?
I have a question regarding airbags on my truck. Would the stress of hard launches at the track, basically pop my rear bags? I've heard from friends of mine, that airbags are the WORST for drag racing. Any suggestions? Right now, I have a flipped axle (5") drop, and I will be soon to have a posi. I want to get the BEST possible traction out of my suspension. So, would making a set of custom trac-bars give me all the traction I need? (Of course with a posi and a good set of drag radials.)
Thanks!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-24-2003, 09:50 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Bags are used by alot of drag racers to control a straight launch from a HIGH torque motor. Put a 4 link and then bag it and you should be ok.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 06-25-2003, 04:04 AM   #3
AccuAir
I totally second that motion. Being able to pre-load the right rear is what most drag racers shoot for, but then you get to drive home from the track crooked unless you have bags. As far as durability, not a problem.
AccuAir is offline   Reply With Quote
Old 06-25-2003, 03:15 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
You will have great traction with a 4-link and airsprings. Often, you can tow and haul more than stock with bags, so there won't be any durability issues.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 06-25-2003, 03:45 PM   #5
fastbagged68
fastbagged68's Avatar
If you go with a 4 link and bags you will be fine. Bags work great for traction as long as it set up right. If you bag your truck with stock leafs and take out some leafs it will light them up- So I would go witha 4 link. and some F9000 behind the axel bags
fastbagged68 is offline   Reply With Quote
Old 06-27-2003, 11:03 PM   #6
1FaastC10
1FaastC10's Avatar
what exactly are "behind the axle bags" ?
i look like a total moron now...
1FaastC10 is offline   Reply With Quote
Old 06-28-2003, 12:29 AM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
That's when the airsprings are located behind the axle. This picture may give you a better idea.
