Old 05-08-2013, 12:32 PM   #1
mookiex4
Question Trouble sourcing out the correct stare. I need help and information....
I have my 65 GMC Truck in the local High school auto shop. they are using it as a project in class. They removed the dead 305 V6 and putting in a 60's Chevrolet 283 built to a 327. It was missing the bell-housing fly wheel and clutch equipment.
I picked up all of that stuff from someone local on Craigslist. I assumed everything was the same. It all bolted up fine but now I am having the following issue with sourcing a starter. The starter I bought after they said they needed one and all others I have been looking through lately are drivers side mounted. The shop teacher said I need the following which is Passenger side mounted. Can someone help me by letting me know what year and type I am looking for. I cannot for the life of me find this starter and not knowing what to ask for doesn't help much.
The one I need is a passenger side with parallel bolt pattern (straight across and parallel with bell housing parting line).
Thanks guys for your time and help.
mookiex4 is offline   Reply With Quote
Old 05-08-2013, 12:41 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Trouble sourcing out the correct stare. I need help and information....
Go here for info....most cases its just a matter of changing the snout...
http://rmcavoy.freeshell.org/starters.html
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-08-2013, 12:42 PM   #3
tincan1966
tincan1966's Avatar
All chevrolet engines have a passenger side mount starter.
Just ask at the parts store for a starter for a 1965 Chevy pickup. w/manual trans. They may ask if 3 speed or 4 spd. You will need to know what size flywheel you have(either 153 or 168 tooth) This is usually dictated by size of clutch a 10 or 10.5" normally is the 153 tooth. 11 and 12 inch clutch will be the 168.
tincan1966 is offline   Reply With Quote
Old 05-09-2013, 09:44 PM   #4
bama63
bama63's Avatar
168 tooth will have a diagonal bolt pattern starter ,the 153 tooth will be straight across bolt pattern starter, hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
