55-59 Headliners, need some pictures
I'd like to see what you guys have for headliners. Stock ones are cool but I'm also looking for ones that have been upholstered.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: May 2011
Re: 55-59 Headliners, need some pictures
Hey dubie, here's a thread that I had started on the topic of headliners
![]() http://67-72chevytrucks.com/vboard/s...ght=headliners
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
This a one piece head liner in a '55
http://67-72chevytrucks.com/vboard/s...d.php?t=475162 |
Not my truck just some examples I liked
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
Parkwood, Was this done with an insert? Overall, how was it done? Thanks,
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
Bob it was done by glueing a hard foam to the roof the then sanding it around the edges to make it flow without any bumps.. once it was smooth he glued one piece head liner to the foam and tucked it under the rubber that holds the windows in to give it the finished look... in a nut shell that's how it's done.. if you need anymore info let me know and i'll do what i can to help you...
#7 | |
1) Is this "hard foam" "1/8-inch PVC foam board"? 2) Is the board formed with heat as one piece, or is it pieced together? Thanks Again,
One thing nice about headliners, they can be changed out any time. They're a little taxing to install, but later on if I should decide to do something better, I can, but probably just keep as is.
![]() Posted via Mobile Device Posted via Mobile Device
First one is mine, next two are from a Toledo Cheese days car show.
Retired and too busy to work. |
Any guesses on what the chrome trim is on the turquoise one?? I can envision the profile, just wondering if anyone knows where to start looking for it???
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Never mind, I found some door edge trim that will work.
Parkwood, I missed the "Thank You" on this one. Great job with the pix, and with Shawn's install!! I'm not sure of the details yet but I'm going to try something like this. It'll show up in my build thread somewhere down the line.
#13 |
Dubie, why not pick up another blanket to use for a headliner?
#14 |
Mine.
#15 |
#16 |
#17 |
This is a very big help to me. With the cab on the rotisserie, I was planning to fab a fiberglass headliner and upper back panel, then cover it, but this will be cleaner, easier and probably cheaper. To be sure I'm on the right track:
