Old 05-08-2013, 04:12 PM   #1
1old67
In need of help anyone running 24x15
ok I have a 72 swb with leaf springs I want to run 24x15 in the back Im going to shorten my rear but what are you guys useing are ya moving the leaf springs to inside the frame or are ya swaping over to a coil crossmember and using trailing arms I would think that would be an easyier route
Thanks for any help
1old67 is offline   Reply With Quote
Old 05-08-2013, 05:58 PM   #2
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
Re: In need of help anyone running 24x15
Idk but I'd like to see pics when done . I think a lot of Drops r Us trucks run 24x15
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 05-08-2013, 06:36 PM   #3
Don't you guys mean 15 x 24? 15" wide x 24" diameter,not 24 wide x 15" diameter,right?
Old 05-08-2013, 07:04 PM   #4
1old67
yea just like drops r us 24X15 Look up dropsrus in houston they have sm really nice trucks
Old 05-08-2013, 08:06 PM   #5
Square_78
Square_78's Avatar
24x15 is a massive rim holding a 405/25r24 tire. The sure look crazy on our trucks. I think most of the guys that can invest $10k into a set of rims have already 4 linked their trucks when they narrow the rear end. I'm guessing you would have to take out about 4" per side?
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-08-2013, 09:35 PM   #6
dirtyjim
dirtyjim's Avatar
There is a 69 on cl houston that's running them with trailing arms. I checked them out when I was buying some parts from him. You might see if the add is still running and ask him about them.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 05-08-2013, 09:53 PM   #7
Jparks
Jparks's Avatar
You might want to message member c10seconds, I just sold him my 24x15 bonspeeds
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 05-08-2013, 10:26 PM   #8
rwade
rwade's Avatar
I'm running a 24X14 raceline. I've narrowed a total of 11" (5.5" per side) and using trailing arms, and its close. I'm not sure you can use a 15" with a trail arm period. You will probably need the 4 link if you set on the 15"
rwade is offline   Reply With Quote
Old 05-08-2013, 11:11 PM   #9
Rochlow
24x15 is huge!!! This truck has 24x12 and I think they are massive!!
http://67-72chevytrucks.com/vboard/s...d.php?t=532127
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 05-09-2013, 05:39 AM   #10
1old67
Any pictures rwade. I haven't ordered the rims yet but I'm about ready fund wise 24x15. Or 24x14 should still be bad @ss. I wounder if I'm only running drop spring will be easier to set instead of haveing to set up bags I really didn't want to just drop it off at a shop to get done I wanted to do my part as much I can do then have a shop do the rest. Thx all.
Old 05-09-2013, 09:58 AM   #11
rwade
rwade's Avatar
I don't have any yet, I'm working on raising my wood floor at the moment. I ordered wheels and put them under there with my rear end out to get the exact width I wanted. The problem comes in with axle width in relation to trail arm mounts and having room to mount rear brakes (I'm using rear disc from classic performance). Also using a 3" block with air bag in stock location. As far as bedside to frame rail, there's plenty of room. If you PM me an e-mail or cell phone number I can send you a few of where I'm at and keep you posted
Old 05-09-2013, 10:30 AM   #12
codeJbird
codeJbird's Avatar
I have 20X14's. I had the rear end narrowed, 4 linked w/ coil overs. I don't see how u would be able to run trailing arms unless they would be custom built. In which case, u might as well 4 link.
Bird
codeJbird is offline   Reply With Quote
Old 05-09-2013, 12:54 PM   #13
1old67
Ok. Thx. Still have a lot of homework to do.
Old 05-09-2013, 01:20 PM   #14
rwade
rwade's Avatar
I'm running them with trailing arms and a 4.25" back space. It's tight, but it will work.
