Sway bar Brackets
I'm looking for a set fo brackets to mount a sway bar on the front of a 71
1971 Cheyenne |
If you are looking for the brackets that rivet to the frame, try your local GM dealer. I just bought a set a few months back for less than $10 per side. GM part number 6271375, AC part number 06271375. Beats the heck out of trying to get someone to cut them off a salvaged truck!
Good Luck, Kent
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
Thanks a lot for the part #. I'm going to go down to the Chevy house and check it out.
1971 Cheyenne |
you will like your truck much better with the sway bar. Great improvement!
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
Have A Nice Day!
You can try here too
ECE About 19$ a pair and can get for lowered or stock height. A friend got some for his lowered 69 and liked them.
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() |
