WTB power drum brake booster
I don't need the master cylinder. Just the booster, and anything else I'd need to hook it up to my '69 and get it working
Thanks Posted via Mobile Device |
Cluster King
![]() Join Date: Nov 2012
Re: WTB power drum brake booster
Send a PM to tll74 (Tom) in Oregon. He may have what you need.
![]() Join Date: Jun 2005
ck10-20-30????
Mine is a C20 3/4 ton '69 with drum brakes front an back. So, I can't use a setup for disc brakes
mastercylinder determines drum or disc. Booster is power or not! Any 69/72 3/4 will work.
#6 | |
Will a 72 booster even mount to a '69 master cylinder? Posted via Mobile Device |
I have one off of a 67 3/4 ton GMC. Unknown condition though, as the truck had been off the road for nearly a year. Lmk if you would like pics or more info.
I have one from a 1970 1/2 ton 4wd. Was driving the truck before switching to one ton. I wont be using it. Do you need just the booster or brackets and all?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#10 | |
I think it may be the difference between a dual diaphragm and a single. My 1 ton booster is the same as my 1/2 ton. And my 1 ton does have the line reversed from the master to the prop valve. Could get pics if you want. I want to go power assist from an Astro Van or such and already switched to front disc. So this will not work for me.
