05-08-2013, 11:22 PM | #1 |
Yup me again with another question
Ok, so I was cleaning out the "collect all" areas on my firewall and I realized that I couldn't get to all the areas. Do you think it would be ok if I drilled a couple of 2inch holes on a few different areas (red arrows) so I could clean out the whole area and keep it cleaner...
1970 C20 Camper Special SBC350 / TH350 '84 C20 Front Disc Brakes/Control Arms |
05-08-2013, 11:31 PM | #2 |
Re: Yup me again with another question
All you have to do is take out the kick panel vent doors to get those area's.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=531265 72 Cheyenne Super 90 Z71 S.B. 434 C.I. Stroker 78 Camaro Z28 (gave to wife she is restoring it) |
05-08-2013, 11:35 PM | #3 | |
Thanks.
05-09-2013, 12:18 PM | #4 |
...or just open the vents while driving around and let the crap blow out all over your legs and floor! LOL
05-09-2013, 12:29 PM | #5 |
Proprietor of Dale's Corner
but it does work though
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-09-2013, 12:44 PM | #6 |
I used a Shop-Vac with a smaller hose adapted (duct taped) to the end and jammed it in from both directions (with the vent removed). It took a little time but not much. Oh...don't use your wife's vacuum hose, she won't let you forget it. Don't ask me how I know.
05-10-2013, 01:38 AM | #7 | |
Appreciate it guys, I will remove the vent and see what I can get.
05-10-2013, 03:30 AM | #8 |
Actually I could see a case for cutting a hole in the outer panel opposite and below the vent to allow cleaning and rust prevention measures you really can't do around the "bell" of the vent hole. Then a semi-permanent coverplate sealed and riveted in place to keep it airtight.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-10-2013, 08:34 AM | #9 | |
After that I ran the garden hose into the cowl from above (after cleaning that out too) and flushed the whole works really good with lots of water to make sure everything was clean and any water could drain. All the junk that fills those areas up comes in through the cowl below the windshield so if you haven't already put a screen in place under there to keep the debris out you might want to consider it. It helps to keep the big pieces out. Good luck!
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
