Old 05-09-2013, 12:03 AM   #1
Dilbert12
Power Steering Pump Brackets for 400 block with no mounting holes..
I actually own a 67 Chevelle, but am swapping in a 400ci small block with no power steering pump mounting holes in the block. I'm also using a PRW long water pump.
I've seen some later Chevy trucks with an arrangement where the brackets connect to the water pump and back to the exhaust manifold... Although I have full length headers and I'm not sure that setup would work or not.
I have a March bracket kit for a P type pump but the assembly isn't going together as I'd like and I was hoping to utilize more of a stock looking setup.
Any ideas what to look for???
If I can't find a solution my fallback plan is to go with a type II pump mounted on the head..not my first choice but I'm pretty sure that would work with very little issues....
Dilbert12 is offline   Reply With Quote
Old 05-09-2013, 12:20 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Power Steering Pump Brackets for 400 block with no mounting holes..
Not related to your question... but I see you're from Orting.
That's my hometown. I was just there visiting my parents last weekend.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
