Old 05-09-2013, 01:18 AM   #1
Kiwi
Kiwi's Avatar
What did it weigh?
What was the approximate curb weight of a 1971 Chevrolet C-10 pick-up truck with: a 350 V-8, TH-350 automatic trans, 2WD, long bed, 6-lug wheels, leaf-spring rear suspension, A/C, etc.?
Kiwi is offline   Reply With Quote
Old 05-09-2013, 02:41 AM   #2
SS Tim
SS Tim's Avatar
Re: What did it weigh?
Don't normally do these but it is an interesting change for me.
Remember weight changes can be very model specific.
72 C10 CE10927 Curb Weight and popular option changes.
Front Rear Total
2280 1546 3826
--36 --11 ---- 350 V-8 Engine upgrade (LS9)
--12 ---5 ---- Turbo-Hydramatic Trans. (TH350)
--90 --10 ---- A/C (C60)
--33 ---0 ---- P/S
--21 ---3 ---- P/B
--19 ---0 ---- Front Stabilizer Bar
---7 ---2 ---- Radio
--10 ---6 ---- Cheyenne Trim
---0 --23 ---- Rear Leaf Springs
(-27) -95 ---- Step Bumper
2481 1701 4182 options total change +356lb
SS Tim is offline   Reply With Quote
Old 05-09-2013, 09:02 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Interesting. Where did you find these numbers?
I am curious about the radio weight though -7# in front and 2# in rear.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-09-2013, 09:59 AM   #4
mrein3
mrein3's Avatar
Simple. The radio weighs 9 pounds and is installed behind the front axle. The weight is dispersed between the front and rear, biased towards the front.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-09-2013, 11:25 AM   #5
wgeyer88
I think he is referring to the fact that it is -7# (negative) on the front axle meaning the front end gets lighter. It looks like its probably a typo and it should be 7# on the front and 2 on the rear.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 05-09-2013, 11:56 AM   #6
Kiwi
Kiwi's Avatar
Good information ... thanks. So, in short a typical '71-'72 weighs around 4,100 lbs.
Now I am curious to weigh my truck as I have installed a host of aluminum items including: cylinder heads, intake manifold, water pump, and radiator.
Old 05-09-2013, 11:57 AM   #7
SS Tim
SS Tim's Avatar
Its not a typo. There are limitations with the WYSIWYG standard editor.
You can't just use spaces and get things to wrap properly. The only negative value is the step bumper unloading the front axle by -27lb.
