Old 05-09-2013, 09:03 AM   #1
jimmy10415368
power steering line
what power steering line yall using on your swaps thanks for any help
jimmy10415368 is offline   Reply With Quote
Old 05-09-2013, 11:53 AM   #2
mej005
Re: power steering line
I was able to use the stock lines with the stock pump, but my truck is an 81. I think 72 and older you can swap out a fitting on the back of the power steering pump and use your stock lines also.
mej005 is offline   Reply With Quote
Old 05-09-2013, 01:46 PM   #3
truckdude239
truckdude239's Avatar
i swaped the fitting out fo the back of my old pump into the new pump and used the stock lines
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-09-2013, 03:24 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I flared the correct fitting onto the line.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-09-2013, 07:18 PM   #5
jorgensensc
jorgensensc's Avatar
For those of you that used the stock lines, did you use big block or small block power steering lines. I tried to reuse my big Block power steering line, but no amount of adjusting will get it off the exhaust manifold Heat shield.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-10-2013, 08:20 PM   #6
wicky
wicky's Avatar
Mine had a big block in it. I had to carefully straighten the line tha run it under the frame in front of the cross member. Kind of a pita but it should work
wicky is offline   Reply With Quote
Old 05-11-2013, 01:07 AM   #7
jorgensensc
Can you take a pic for me?
Old 05-11-2013, 01:21 AM   #8
clinebarger
Small block PS hoses work better.
clinebarger is offline   Reply With Quote
Old 05-11-2013, 01:36 AM   #9
jorgensensc
Really! Thanks!!
Old 05-11-2013, 12:56 PM   #10
nickbwilson
i have the same question only im running the ls1 power steering pump and need to connect that to my steering box my truck is a 79 aybody have any idea where to get the proper hoses
nickbwilson is offline   Reply With Quote
Old 05-11-2013, 01:35 PM   #11
jorgensensc
Wait wait!! I can answer that question!! Just unscrew the fitting off of the power steering boxes and swap them. That's what I did. Then you can use the stock power steering hose for the '79.
Old 05-11-2013, 07:26 PM   #12
clinebarger
If your running a Camaro or Corvette LS1 pump....There is no "bolt-on" hose out there....
Old 05-11-2013, 09:37 PM   #13
jorgensensc
Well I Guess I didn't have the answer......EPIC FAIL.
Old 05-11-2013, 10:54 PM   #14
clinebarger
Power steering pumps/Accessory layout are body line specific, Using car engines in trucks has drawbacks....Like custom power steering hoses.
Old 05-11-2013, 11:21 PM   #15
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I used these parts to build my own...
Updated Quantities and Part Numbers:
2 ea -6 to 90° hose ends (RUS-620421)
3 ft Russell power flex hose (RUS-632600)
1 ea -6 90° swivel hose end (SUM-220687B)
3 ft Summit -6 braided hose (SUM-230603)
1ea EAR-991947ERL -6 TO 5/8-18 (box)
1ea EAR-991950ERL -6 TO 11/16-18 (box)
1ea EAR-991955ERL -6 TO 16MM X1.5 (pump)
Note: I didn't use the full 3 feet of either hose, cut and fit them how you like.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-14-2013, 03:00 AM   #16
5150
C10 Club Tennessee
5150's Avatar
If you go to Napa and get fitting 1446 and screw that into the back of the pump you can use the stock line. I paid $10 for the fitting.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 05-14-2013, 05:20 AM   #17
ls1nova71
ls1nova71's Avatar
Probably only on a truck pump. The LS1 pump on an F body the line comes out the side and is a completely different fitting. What I've done in the past was to use the Camaro line and cut the rack end off and flare it, then cut and flare the original line where it goes to the box and connect them together.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
