Old 05-09-2013, 11:17 AM   #1
First c10
First c10's Avatar
Sway bar bushing
Hey guys
I was installing the sway bar and noticed that the angle of the sway bar at the lower arm on the passenger side was at an angle not up or down but from drivers side to passenger side and when I lower the truck back on the ground the bushing started to pop out where the split is. Is the split of the bushing supposed to be on one side or the other? I have seen in other pictures both ways. The bar was straight and lined up between the bolt holes on the a arm.
What should I do? Re drill the inside bolt hole towards the back of the truck so the bushing sits at the same angle as the sway bar?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-09-2013, 11:20 AM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Sway bar bushing
Can you take a pic of what you are talking about?
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 05-09-2013, 11:26 AM   #3
First c10
First c10's Avatar
I forgot to before I left last night. (Late night). I will try tonight sorry.
GO GO!!!
Old 05-09-2013, 11:45 AM   #4
1972SUPERSB
Ok that's cool. I just put on my sway bar too. I doesn't matter which way the split on the bushings go on. There should be 2 bends on each end of the bar where it clamps to the a arm
Jeff
Old 05-09-2013, 11:53 AM   #5
First c10
First c10's Avatar
Mine is the original that came with the truck. I just painted and replaces bushing After lowering it.
GO GO!!!
Old 05-09-2013, 12:49 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You've likely got the bar on upside down. It's easy to do and will cause the bushings to open up like that since the angle is wrong.
Old 05-09-2013, 01:32 PM   #7
First c10
First c10's Avatar
I looked at the forum and the sway arm has a curve to keep it away from the steering pitman arm and idler arm. Right. ?
GO GO!!!
Old 05-09-2013, 01:45 PM   #8
Tx Firefighter
I've put a bunch of them on over the years, and just a few months ago, I put mine on upside down until I figured out my mistake. It's easy to do.
Here it is after I turned it over the right way. It was prying the bushings open like you describe before I flipped it over right.
Old 05-09-2013, 05:30 PM   #9
First c10
First c10's Avatar
That's how mine looks. Same as the picture.
GO GO!!!
Old 05-10-2013, 01:32 PM   #10
First c10
First c10's Avatar
Here is a picture of the bushing that popped out
GO GO!!!
Old 05-10-2013, 01:48 PM   #11
1972SUPERSB
Looks like you may not of had it sitting right when you bolted it down
Jeff
Old 05-10-2013, 04:52 PM   #12
First c10
First c10's Avatar
possible it was a long night!!!! I will try and reseat it. possibly to much lube!
GO GO!!!
Old 05-11-2013, 02:00 AM   #13
First c10
First c10's Avatar
I took the wheels off and reset the bushing and maid sure the bushing was seated as I tightened it. It seems to be ok we will see once I get the alignment and drive her.
GO GO!!!
Old 05-11-2013, 10:39 AM   #14
1972SUPERSB
Ok cool let us know
Jeff
Old 05-11-2013, 01:33 PM   #15
ERASER5
ERASER5's Avatar
I painted my bar the same color. Cool!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-11-2013, 02:32 PM   #16
Tx Firefighter
I love that stuff. I use it with gloss clear for some stuff like the sway bar.
But it looks even better with flat clear coat.
Old 05-11-2013, 02:39 PM   #17
Rufton
That paint does look good.
Rufton is offline   Reply With Quote
Old 05-11-2013, 02:45 PM   #18
1972SUPERSB
What type and color of paint is that?
Jeff
Old 05-11-2013, 02:50 PM   #19
Tx Firefighter
It's silver vein powdercoat. I order it from NIC Prismatic. Their powder has the most pronounced vein effect of all of them out there that I've ever seen.
Old 05-11-2013, 07:03 PM   #20
stsalvage
Scrapper 1
stsalvage's Avatar
look up WWW.4Wheelwest.com they make a Zerk fitting like your ball joints and A Arm bushings where you can take a grease gun and Lube your sway bar bushings i think i have a picture of my 1965 3/4ton with them
stsalvage is offline   Reply With Quote
