![]() Join Date: Sep 2011
'66 C30 E-brake
The E-brake cable passes thru a drum? thingy at the back of the tranny on it's way to the rear wheels. On mine the lining is severely worn.
So, what is this part called and where can I get a new/rebuilt one? Thanks guys. Posted via Mobile Device
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: '66 C30 E-brake
You might try a shop that works on medium and heavy duty trucks. Or you might need to send it somewhere that can rivet new lining on it. It's been so long since I've been under my C30, are there shoes inside a drum, or is it a band on the outside of the drum? On my '63 C60, there is a band on the outside. I had that one re-lined when there was still a local place that did that.
Re: '66 C30 E-brake
Cap'n mine is like yours. Thanks for the info.
