Old 05-09-2013, 01:30 PM   #1
Warp Speed
Radio Antena Wire Routing
I have searched and found nothing. I know lots of people here know these trucks inside and out. How is the wire for the antena supposed to be routed and were is the pass through?
Thanks......
Warp Speed is offline   Reply With Quote
Old 05-09-2013, 03:26 PM   #2
dracko
dracko's Avatar
Re: Radio Antena Wire Routing
Antenna should be located on the passenger side cowl corner piece....the small square panel above the fender and beside the cowl. If you open the door and pop the hood you can get to the bolts to remove it. There is a hole with a grommet under it to feed the cable through.
dracko is offline   Reply With Quote
Old 05-09-2013, 03:38 PM   #3
Warp Speed
The upper fender/cowl panel has the hole for the antena, but I don't see one under it leading into the cab. Anyone have a pic of where the hole should be?
Old 05-09-2013, 03:45 PM   #4
1963c-10
1963c-10's Avatar
Alot of the Baltimore trucks mounted them on the driver side as mine was. I have had 2 baltimore trucks w/driver side antenneas.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-09-2013, 04:40 PM   #5
forestb
forestb's Avatar
I think mine was snaked in between the cowl corner piece and the cab into the engine compartment and from there it went into the cab through a hole that was in the center of a little round bump (I don't know the technical term for that) on the fire wall.
forestb is offline   Reply With Quote
Old 05-10-2013, 07:46 AM   #6
ljackson
ljackson's Avatar
Mine has a hole that was punched into the cab corner under the cowl piece. It looked like someone used a center punch and drove it through the sheet metal. I don't if this is how they did it at the factory, dealership or if the owner did it? I believe my truck does have the original radio though. The cable goes over or behind the glovebox to the radio.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 05-10-2013, 05:59 PM   #7
BrokeTillDone
BrokeTillDone's Avatar
Thanks......
Here are some pictures for reference on mine.
BrokeTillDone is offline   Reply With Quote
Old 05-10-2013, 07:24 PM   #8
1963c-10
1963c-10's Avatar
alot of trucks were not ordered with a radio, and had delete plates instead. if installed at the dealer, it may have been installed on either side also.
Old 05-10-2013, 08:41 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The hole above is probably the best reference, just add plenty of silly-cone to the hole
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-10-2013, 08:45 PM   #10
jbgroby
jbgroby's Avatar
On my '60 the hole is in a slightly different location, so it is more than possible that the factory/dealer popped the hole in after the customer ordered the radio.
see below for my location.
jbgroby is offline   Reply With Quote
