Old 05-09-2013, 06:03 PM   #1
budman k20
1972 K20
2in lift blocks tapered?
I put on a Tuff Country 2in lift on my 72 K20 and I didn't put the rear spacer blocks in right away. So far I've put 1000 miles on it and it rides rougher than I would like but no vibrations. Now after I put in the 2in spacer blocks in the rear I see they are tapered. Why are my 2in lift blocks tapered? Don't you want the rear pinion angle to be parallel to the driveline? The reason I ask is I now have bad vibrations after putting the blocks in! Anyone else have this problem and what did you do to correct it?
budman k20 is offline   Reply With Quote
Old 05-09-2013, 06:23 PM   #2
LONGHAIR
Re: 2in lift blocks tapered?
First of all, no, you don't want the pinion to be in-line with the driveshaft. That makes for no movement of the joint itself. That is not good for the bearings. They need to roll, otherwise they sit in one place and beat up the surfaces were they make contact.
As far as the blocks, if nothing else changed at the time of the install, I would swap them for an un-tapered set.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-09-2013, 07:22 PM   #3
budman k20
1972 K20
Yes I did say driveline... but I was reffering to the engine and trans not the drive shaft. By tapering the blocks the pinion angle is going up I assume to compensate for the lower rear axle position? Everytime I do something to my truck it seems I have to do it twice!
Old 05-11-2013, 01:15 AM   #4
snj8198
snj8198's Avatar
the taper is so you can tilt the diff angle down to compensate for the lift. pinion angle is usually 2-3 degrees down ward so when torque is applied from the drive line the pinion rotates to 0 under power. Tuff Country cuts this angle into the blocks so you don't have to add a shim to get this effect.
i know your pain, sometimes it takes a couple shots at a project to get it right. good luck
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 05-11-2013, 09:35 AM   #5
obijuan
did you lower the transmission crossmember? sometimes i have seen instructions telling you to drop the crossmember an inch. that will help keep the angles down. however, i think thats a cheap way out. i dont condone it really. it can crack the frame at your trans mount holes if you follw the instructions and use those factory spacers and just move em. maybe 1"x2" rectangular tubing would suffice.
go to tom woods driveshafts website and they have a diagram showing you how each setup should be and the reasons why.
the cure all is a CV rear driveshaft with the pinion pointed at the tcase.
obijuan is offline   Reply With Quote
