Old 05-09-2013, 10:12 PM   #1
chris1htx
Running out of options
Today I changed out my shocks because every bump I would hit, the truck would slam on the bump stops. I thought getting better shocks would help solve that problem, it slightly did but the bump stops are still getting hit. With only a two inch drop I wouldn't think that would be a problem. Anybody know anything else I can try rather than shaving off the bump stops?
chris1htx is offline   Reply With Quote
Old 05-09-2013, 10:20 PM   #2
texas gmc
Re: Running out of options
I'm guessing you have lowered coils or cut springs?
texas gmc is offline   Reply With Quote
Old 05-09-2013, 10:21 PM   #3
chris1htx
Lowered springs
Old 05-09-2013, 10:25 PM   #4
texas gmc
That doesn't seem right, but I have no experience with lowering coils. I know cutting coils mess the spring rate up. But that's not your issue.
I have 2.5" spindles and it rides like stock.
Old 05-09-2013, 10:35 PM   #5
chris1htx
It's very frustrating I don't know what to do
Old 05-09-2013, 11:15 PM   #6
DREAMER1
DREAMER1's Avatar
Don't know if it'll help, but I cut 1 coil off my stock springs, with a 2.5 drop spindle....then we cut the entire bump stop mount. I have 20" wheels. Every once in awhile when I did a pothole too hard I rub the top of the inner wheel well. I never have "bottomed out".
DREAMER1 is offline   Reply With Quote
Old 05-09-2013, 11:39 PM   #7
cory d
cory d's Avatar
the stock coils and most drop coils are just too soft for these nose heave trucks.
cory d is offline   Reply With Quote
Old 05-09-2013, 11:40 PM   #8
andrewmp6
You sure its the bump stops not the shocks bottoming out?
andrewmp6 is offline   Reply With Quote
Old 05-10-2013, 08:58 AM   #9
chris1htx
yeah it's the bump stops, the metal was cleaned of all it's dirt from all the times it would hit.
Old 05-10-2013, 10:29 AM   #10
bigwheel15
bigwheel15's Avatar
Might have to put shorter bump stops in from what ive read. Or possibly a more stiff shock.
bigwheel15 is offline   Reply With Quote
Old 05-10-2013, 02:15 PM   #11
PAPA KENT
PAPA KENT's Avatar
you might want to try cutting off half of your rubber bump stop and see if that cures it.
kent.
PAPA KENT is offline   Reply With Quote
Old 05-10-2013, 07:49 PM   #12
LEEVON
Moderator
LEEVON's Avatar
Chris, sorry you have this problem. Do you have any pics or part numbers, etc.? Any information you can give might help.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-10-2013, 09:27 PM   #13
J Knight
J Knight's Avatar
Lowered springs
Its a simple matter of suspension travel, with a 2in drop you have to remove the bumpstop pad but you will still hit the top of the bumpstop mount on occasion. Your going to have to cut them out or put the stock springs back in and get some drop spindles.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-10-2013, 09:40 PM   #14
Damon23
Damon23's Avatar
I agree with the stock springs and spindles. Dropped mine with 2.5 in western chassis spindles and rides like stock.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
