72 2wd Gm 700R4 crossmember help
Not sure what crossmember to use on a 72 Gm 2wd that had a v8 with an engine mounted 3speed trans. Could someone tell me what year crossmember I need and from a T350 or a T400, is there a difference as installing a 700R4 now. Thanks/Mudman.
Re: 72 2wd Gm 700R4 crossmember help
A cross member from a 350 0r 400 will work u will have to remove your 3 speed x-member.They are a PITA to remove and install when I had mine out I took a grinder to all 4 corners and rounded them off,it seemed to help.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
