Old 05-10-2013, 01:50 AM   #1
Daveyboy1983
Brake Backing Plate
Ok so when I took the front suspension of my truck apart 3 months ago I took the backing plates/dust shields off the spindles so I could have everything sand blasted and now I have made a couple of problems for myself...
One: Rookie mistake I forgot which way the plates go back on lol So does anyone have a pic or could tell me which position the hole in the plate goes is it towards the top or bottom of the spindle?...
Two: There was a rubber gasket that went between the backing plates and the spindles and now I have lost them both (I wanted to replace them anyway they were falling apart) but what are they called exactly? And I went to a couple of parts stores and tried to describe what I was looking for and they both told me I was crazy basically so any help would be great thanks...
Daveyboy1983 is offline   Reply With Quote
Old 05-10-2013, 06:56 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Brake Backing Plate
The holes go down. They are for the lower control arm edge to have clearance. You will also note that the large cut out goes toward the back of the truck. This is where the brake caliper goes.
You're gonna be out of luck on the little rubber gasket deals. Just put a nice little bead of silicone around the spindle and bolt the plates into place. The silicone will substitute nicely.
Old 05-10-2013, 07:00 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
might help
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-10-2013, 08:07 AM   #4
Daveyboy1983
That did help guys thanks a lot for the input I didn't even think of just using silicone for the backing plates thanks again
Old 05-10-2013, 11:03 AM   #5
wraprail
wraprail's Avatar
Originally Posted by motornut View Post
might help
Holly Cow man you don't have to worry about those parts rusting!
Is that what 500,000 miles looks like?
wraprail is offline   Reply With Quote
Old 05-10-2013, 11:27 AM   #6
Daveyboy1983
I also forgot to mention that I have the front of the truck lowered 4.5 inches 2.5 drop spindle and cut coils and should I even bother running the backing plates?
Old 05-10-2013, 01:55 PM   #7
83GMCK2500
Gasket, Steering Knuckle to Front Brake Flange Plate -> GM P/N: 3966202
Good luck in your search.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-10-2013, 04:03 PM   #8
wraprail
wraprail's Avatar
Dude, I wasn't gona say but now that you mention it.
I havn't used the front (or rear) brake rotor dust shields for 13 years.
That is on 2 trucks, a 74 C10 and my current 85. Both lowered.
I think one function has to do with keeping water from the rotors and it almost never rains here. When it has I have never had any problems not running them
When you don't have inner fenders it looks cooler too.
I don't use the rears either.
Old 05-11-2013, 06:33 AM   #9
rusty76
rusty76's Avatar
Not used on race cars either. Motorcycles don't have either, I do believe. Most hot rods I've seen don't use'em, espeacially open wheeled. I'm curious to if you need'em or not.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-11-2013, 09:33 AM   #10
homemade87
I always thought they were for helping keep mud splash from collecting in the rotor and also from keeping something from wraping around the rotor incase you run over something that had that potential. I don't think they were for rain.
If Keith is watching maybe he can inform us.
homemade87 is offline   Reply With Quote
Old 05-12-2013, 08:28 AM   #11
bigd65
bigd65's Avatar
They keep the junk out of the brakes. However, ALOT people do away with them if the vehicle is NOT a daily driver. Then you would be more apt to avoid potholes full of mud and water, or running over things on the road.... If I your truck is a daily driver, I would recommend putting them back on, it's your brakes !!!!!
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 05-12-2013, 08:44 AM   #12
wraprail
wraprail's Avatar
I have never got anything in my brakes besides air and my truck is my only automobile so I drive it everyday and often.
Maybe they improve air flow?
Old 05-12-2013, 10:04 AM   #13
Daveyboy1983
Well I don't see the harm in running them especially when I've already blasted and painted them lol
Old 05-12-2013, 10:37 AM   #14
homemade87
The other thing that came to mind is if you were running 70mph on the interstate and run over a tractor trailer tire and got the steel cord wound around the spindle and locked up one wheel at 70mph. Would not be a good day. Whats the chances of that happing . Although people do win the lottery.
Old 05-12-2013, 11:49 AM   #15
Daveyboy1983
The odds of me locking up a wheel at 70mph are probably better haha!
Old 05-12-2013, 12:36 PM   #16
Tx Firefighter
I can't tell you an educated reason as to why the GM engineers put them on the truck, but I guarantee you they had a very good reason. You know how manufacturers are, they aren't gonna spend a single cent on something without a good reason. Think of all the millions of these trucks they sold and how many dollars they spent putting the two shields, six bolts, and two dust seals on each truck over the years.
I've run both cars and trucks without them and never had any problems, but those were aftermarket Mustang II set ups and I never had them to start with. If I'd had them, I'd have installed them.
Old 05-13-2013, 07:33 AM   #17
wraprail
wraprail's Avatar
I do agree with TX totally.
I Don't use them cuz when I open my hood they look like crap. (No inner fenders)
There, I said it!
Looks more better without
