Old 05-10-2013, 08:28 AM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Anyone change the "wind chase" in your doors?
Both of my doors need the "wind chase" repaired. The passenger door is missing completely and the driver door is missing one of the pads that pinch together to stop the door from opening too far. Does anyone make these? Has anyone ever swapped them? I sure don't want to have to change the complete hinge.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-10-2013, 09:16 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Anyone change the "wind chase" in your doors?
What's a wind chase?
You may want to post a pic of what you need and/or look at the LMC catalog since they have good illustrations and post the page and item number.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-10-2013, 09:38 AM   #3
Daner
Daner's Avatar
I made my own dohicky to keep my drivers door from opening too far. Sorry I don't have any pics. I roughly cut the shape out on some scrap I had then guessed how long the pin needed to be to catch the door... drilled a hole in the pin, added a cotter pin to hold the pin at the right height inside the door and it works. It doesn't look pretty but I'm the only one that sees it. The door is creased already anyway.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 05-10-2013, 09:40 AM   #4
camrycurt
camrycurt's Avatar
I think you're talking about the mechanism in the hinge that holds the doors open? If yes, then I've seen the pads referred to as "friction pads" but I don't think anyone makes a replacement kit.
I know some guys have cut up old brake pad material and used that to replace the pads, so you might try that to replace your one missing pad. Do a search here on the forum for "friction pad" and you should find the threads.
For the one hinge that's missing everything, I think your only choice is to buy a replacement hinge, either new or used.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 05-10-2013, 09:58 AM   #5
LONGHAIR
The wind "check" (not chase) is built into the hinge. It is not an independant unit like a van door, so it is not likely to be rebuildable. It is part of the hinge "assembly"
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-10-2013, 10:15 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Got it. This part has a lot of different names -Door check, door hinge stops, door catch, door friction stops or pads.
Some one posted that Classic Parts has a repair kit. Might need to call the vendor and check with them since everyone uses a different name for the part.
06 Trailblazer
Old 05-10-2013, 10:35 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Classic Parts used to sell the friction pads for the door detent. They no longer do, but I believe there is a replacement procedure outlined in FAQ.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-10-2013, 11:04 AM   #8
NGN
NGN's Avatar
Are you talking about the parts that are mounted in the front pillar and squeezeies the lever that comes off the hinge. I looked through the LMC up dated spring edition 2013 and did not find that part. I know I seen them parts somewhere, they're made with a teflon on plates.If this is the part you are talking about.
NGN is offline   Reply With Quote
Old 05-10-2013, 11:12 AM   #9
NGN
NGN's Avatar
Yeah' what leddzepp said.
Old 05-10-2013, 01:25 PM   #10
C10_ustacould
Found this in the FAQ section, but the parts are no loger sold. I guess I am going to have to put upper hinges on both doors.
http://67-72chevytrucks.com/vboard/s...oor+hinge+stop
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-10-2013, 03:37 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by leddzepp View Post
Classic Parts used to sell the friction pads for the door detent. They no longer do, but I believe there is a replacement procedure outlined in FAQ. Posted via Mobile Device
I guess either not enough demand or they want to sell the whole door hinge asm. If my door hinges were in good shape I think I'd try to find some way to repair those door detent pads.
06 Trailblazer
Old 05-10-2013, 03:54 PM   #12
jorgensensc
jorgensensc's Avatar
You should ask in the classified section if anyone has a used hinge that you could buy. Then use the parts to fix yours.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-10-2013, 03:58 PM   #13
C10_ustacould
I actually have 2 full set of extra hinges, the problem I am having is removing the roll pin. I can't get it out of the hinges. I did get the one out of my passenger door, but it was destroyed when I was finished.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
