I Like Mine With No Shine!
![]() Join Date: Apr 2009
I've got a 71 non ac cab with clean title and a 67 frame that I haven't had any luck selling. I hate to cut them up but I need to move them. So....let me know what you need cut and the zip code to where the parts will be going. Prices starting at $20 for patches of the cab or pieces of the frame.
OR Take the cab whole for $500 and the frame whole for SOLD.... I'll give this a week or two, then its all going to the scrap yard.... Pictures of the frame and cab can be found here.....pages 3-7 http://s630.photobucket.com/user/wan...?sort=3&page=3
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 Last edited by wancosc356; 05-30-2013 at 10:02 PM. Reason: Sold frame |
Re: 71 Non AC Cab and 67 Frame.....cutting up for pieces and patches
Bump
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
How about under the dash cowl on the passenger side.
Brad handshoe |
I'll check it out tomorrow and get back to you.
is the frame a lwb or swb? im interested in the whole frame. is it straight with no bends or anything!? text if easier. 757-358-4542
SWB. It is straight with only the very front piece twisted. I have a straight replacement piece to go with it though. It looks like it got twisted when someone used a tow hook and yanked it. Check out the pictures. Its the U or V shaped piece right in front of the front cross member.
Where are you in sc? Interested in the frame , do you have any trailing arms?
Florence, SC. I don't have any trailing arms or rear axles. Sorry.
Did you get a chance to look under the dash at the inner cowl? Thanks
Brad handshoe |
If you start cutting the frame I could use both sides directly over the rear end 1' in both directions. previous owner did a homemade step notch and hacking the frame. Shipped to 75002.
Posted via Mobile Device |
I need the driver's side core support bracket if you're still parting the frame. It's the one I circled. Mine's pretty twisted up.
#13 | |||
Shoot me a PM. Depending on where you have a pickup, I might be able to help you out.
#14 |
My frame is a '69, but the core support mount is the same 67-72. Let me know what you want for it.
Thanks Al |
#15 | |
#16 |
As far as I know, the mount itself is different, not the frame. I'm using a '68 front clip anyway, so the '67 will fit perfectly.
#17 |
![]() Join Date: Nov 2012
If you decide to cut the frame I would be interested in both front frame rails from suspension forward. Let me know.
#18 | |
But if you are gonna use a 68 front clip with a 68 core support, these will work for you. Ok. Sounds good. Will let you know. Waiting to hear back on someone interested in the whole frame.
#19 | |
Thanks, Al |
#20 |
Frame sold to bodydropped72 pending pickup and payment.
Al, I may have another set of mounts....do you want one or both?
#21 |
I just need the driver's side. My passenger side one is straight. Thanks!
#22 |
Any chance you might be able to chop a bedside up? I need the tail light section from the left bedside. Approx 2-3in above and below the tail light assembly and about 3-4 inches down the side of the bed. I know this completely ruins the rest of the bedside, but if you don't have any takers for the whole bedside, and are planning on scrapping it anyways, it might work out. Let me know! Thanks!
#23 |
Just checking in, you happen to have that bracket? Going to be having my frame blasted soon and need to get that on there.
Thanks! Al |
#24 | |
Sorry for the delay. The frame is gone but I do have a set of brackets. I'll get back to you tomorrow.
#25 |
Never heard back, let me know if you have the brackets.
Thanks, Al |
