Old 05-10-2013, 04:55 PM   #1
mdeal
mdeal's Avatar
Door Lock issues. Help!
I have a 71 C10 that I'm changing the door locks on since the truck came with no keys. I bought a kit and I installed it today. The key will turn completely, locking & unlocking the doors properly, only when the door is open. Once I close the door, the lock cylinder will only turn a 1/4 of the way needed to completely lock & unlock the door.
What can I do to solve this problem?
mdeal is offline   Reply With Quote
Old 05-10-2013, 05:13 PM   #2
geezer#99
geezer#99's Avatar
Re: Door Lock issues. Help!
Lean on the door and push it in while turning. The star wheel is worn out. If that doesn't help it then you'll need to replace the complete latch assembly.
Old 05-10-2013, 06:13 PM   #3
JointTech
JointTech's Avatar
yea i hip check my passenger side door when locking it.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-10-2013, 09:22 PM   #4
Square_78
Square_78's Avatar
My passenger door is also the same way. Need to push on it slightly to get it to lock
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-10-2013, 09:26 PM   #5
mdeal
mdeal's Avatar
Yep. That worked. I guess I'll just hug my truck every time I lock the doors...
Thanks for the info!!!
