Old 05-10-2013, 07:56 PM   #1
gipper
Need Suggestions!
I have a 1968 GMC stepside with a 350 engine and automatic transmission. Every once in a while, when I go to start it, it will not start. Acts like the battery is completely dead. No clicking no nothing! I wait a half hour or so and it will start right up. Seems to do it after I have driven it a bit. Did it twice last year and when I pulled it out of storage, drove it for an hour or so it did it again! Over the winter, I replaced all the battery cables and the complete ignition system. I am baffled as to what it can be.
gipper is offline   Reply With Quote
Old 05-10-2013, 08:01 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Need Suggestions!
Sounds like the starter solenoid may be getting hot. Have you replaced it recently? Will it start with a jump or do you have to wait for it to cool down?
Where in the heck is Fruitport?
TBONE1964 is offline   Reply With Quote
Old 05-10-2013, 08:03 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Oh, I found it over there on the west side.
Old 05-10-2013, 08:07 PM   #4
cdowns
cdowns's Avatar
take two battery cables off battery clean 4 ends of battery cables clean all places where cables go conect cabels back
Old 05-11-2013, 06:57 AM   #5
gipper
I have not replaced the solenoid. I have not tried to jump it but solenoids are cheap and I will replace mine. Thanks!
Old 05-11-2013, 07:33 AM   #6
elf w/capital T
I had the same issue, clean all points on power and ground for starter and battery.
GOod luck
elf w/capital T is offline   Reply With Quote
Old 05-11-2013, 10:51 AM   #7
Robznob11
Robznob11's Avatar
as stated above ends probably need cleaned. sounds like a ground issue but could be on either side. also if it has clamp on replacement ends or any cut and spilces I would check them close. over time moister will crawl down the line and corrode the wire sometimes up to a foot inside the cable and that will cause enough voltage drop to create your situation.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-11-2013, 11:02 AM   #8
big mike71
big mike71's Avatar
Next time it does it move the gear shift lever a little and see if it starts. Mine does that it's the neutral safety switch.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 05-11-2013, 11:21 AM   #9
CC69Rat
CC69Rat's Avatar
Does it have headers on it? Sounds like starter / solenoid heat soak to me.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-11-2013, 11:53 AM   #10
gipper
I think you hit the nail on the head! I do have headers. Since I have all new cables, I am pretty sure that is not the issue. I have a friend in the auto salvage business and I picked up a heat shield for the solenoid. Will install that stuff tomorrow. I am hoping this will solve my issue. Thanks
Old 05-11-2013, 12:12 PM   #11
jorgensensc
jorgensensc's Avatar
Sounds a lot like heat soak to me. Get a ford remote starter relay. Or if you can't stand to have a ford part on your truck you can use the one that GM on thier motorhomes. (Its the same exact thing). Done it on many a truck. Works great.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-11-2013, 02:52 PM   #12
CC69Rat
CC69Rat's Avatar
You may try a little heat wrap on that #6 header tube as well. Anything to pull some of the heat off that solenoid.
Chad
