Old 06-24-2003, 02:16 PM   #1
adkphoto
Question Mechanical fuel pump ?
I got a brand spankin' new Edelbrock mechanical fuel pump to compliment my new engine.
My question is .... the stock setup has a return line to go back to the tank, but the new pump only has inlet and outlet (to carb) ports.
Can i just block off the return line to the tank or is there a goos reason why I shouldn't?
David
1972 Chevy Cheyenne Super LWB
Chevy Red/White with rally wheels.
Not-so-Stock 350, A/T, A/C, tilt.
Vroom, Vroom....
David Colbert dcolbert@twcny.rr.com
Work hard, play harder!
adkphoto is offline   Reply With Quote
Old 06-24-2003, 02:23 PM   #2
bpmcgee
bpmcgee's Avatar
I believe that the return line is what keeps the pump from providing too high a pressure to the carb.
Since the pump is driven by the crank, the faster the engine turns the higher the pressure. Most carbs don't like more than about 7 PSI.
Can you get an edelbrok pump with the correct plumbing? That would be the best solution, IMHO.
Brian
bpmcgee is offline   Reply With Quote
Old 06-24-2003, 02:38 PM   #3
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
I ran into this very problem a few years back and if I remember correctly this also ties in with the charcoal canister and fuel tank vent system. I plugged the system and went to a vented cap, but the tank still didn't vent very well. I'm not sure what the correct solution is and I looked all over for a schematic of the fuel system, I never did find one. Good question!
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 06-24-2003, 02:59 PM   #4
mdill
Be carefull when replacing the lines to the
canister, GM put restictors in some of them,
so when replacing a vent line be sure to check
and see if there is a restrictor in the old line.
If so cut it out and put it in your new line.
Mike D.
72 3/4 ton 4X4 Suburban
(and way to many FSJ's (J series jeeps)
mdill is offline   Reply With Quote
Old 06-24-2003, 03:09 PM   #5
GREEN70-72
GREEN70-72's Avatar
If I am not mistaken(an I may be) don't mech. fuel pumps have a set range from the factory. and they have a port(hole,whatever)for atmospheric(sp?) reference?
70 SWB, 4/6" DROP,20X8 & 20X9.5. BOYD TIMELESS 5,93 BURB POWER SEATS, BILLET SPECIALTIES STEERING WHEELS. SOON TO BE VOTECH AND TBI POWERED. O YEA AND WAL-MART IS THE DEVIL!!!
GREEN70-72 is offline   Reply With Quote
Old 06-24-2003, 03:37 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Read the instructions on your carb, if memory serves, that pump is more like 15 PSI. You'll need to run a fuel pressure regulater and if it has a return line on the regulater, then just hook it to your existing return line.
If you have a choise of a reg with, and one without a return line, get the one with a return line. It helps to keep your fuel cooler and puts less wear on your pump.
Old 06-25-2003, 09:42 AM   #7
adkphoto
Actually the fuel pump is supposed to match the Performer series carbs and put out 6 psi.
Here's a link from Summit: http://store.summitracing.com/partde...=MG&part=12478
I was always under the assumption that the fuel pump pressure is constant and the volume changes with RPMs. Somebody correct me if I'm wrong.
Just to play devil's aadvocate... If a bypass back to the tank is needed, why do they make mechanical fuel pumps with only inlet and outlet ports?
David
Vroom, Vroom....
Old 06-25-2003, 03:54 PM   #8
Longhorn Man
Becouse some carbs wan 6 PSI, and some aftermarket race only carbs may want 12 psi. This way, you can use the pump that pumps 15PSI and 'govern' it down to 6 and have a good return flow going to help with vapor lock. The high line pressure also would help with vapor lock.
