Old 05-11-2013, 01:39 AM   #1
sir_talk_alot
sir_talk_alot's Avatar
92 5spd swap in my 70
Is this smart to do? Im really wanting to get rid of the t350 and go standard. Just found a 92 truck 5 spd on craigslist for 150. Whats it take to swap? Can it handle 400hp sbc? Or should i buy it and save it for the 3/4 c20 i want for pulling stuff. I wanna make the truck more fun to drive
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 05-11-2013, 02:33 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 92 5spd swap in my 70
Search 'NV3500' (might also try MG5 or Getrag 5 speed) plenty of info on the forum already.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-11-2013, 02:54 AM   #3
SS Tim
SS Tim's Avatar
Put it towards the Cheyenne Super. That looks like it could be a good start.
SS Tim is offline   Reply With Quote
Old 05-11-2013, 01:14 PM   #4
airdale94
airdale94's Avatar
If it's the NV4500, I would put it into the C20. I don't think you would want a NV3500 in a 400hp street truck. I would go with a T5 or T56. The early GM 5spds are Gertrag. I heard you want to stay away from them. Especially the heavy duty ones.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 05-11-2013, 01:43 PM   #5
sir_talk_alot
Its probably a 3500 and if it goes in my street truck itll be behind 400hp. If it goes in a c20 itll just replace the old 4spd as a work truck with overdrive gears as a dailydriver
-Mike-
Old 05-11-2013, 06:47 PM   #6
airdale94
airdale94's Avatar
I would do either a rear end swap, if you have the H052 you can do a 14bolt out of a 73-87 then you can run whatever gears you want. Or if you have the Dana you can probably get gears for those. The 14 bolt is what I want to do. You really can't beat those old truck 4-speeds. There fairly easy to rebuild. Novac has kits and instructions for them. I like my gears to run me about 2500 RPM at 65mph. 3.55 will put you a little over 2500. You can go clear down to 3.08 if you don't do alot of really heavy towing.
Old 05-11-2013, 07:07 PM   #7
stsalvage
Scrapper 1
stsalvage's Avatar
you must be young and live in a city with not that many car's on the road.here in Calif we welcome a 700R4 any day to spending 2 hours on the freeway in bumper to bumper traffic
stsalvage is offline   Reply With Quote
Old 05-12-2013, 09:03 PM   #8
Gumby'sC20
Gumby'sC20's Avatar
I'm currently working on a later model NV3500 (model year 93+). They're the single-rail 5 speeds, versus the earlier 4 rail units used until 1992. They're a bit more reliable than the 4 rail you're looking at on Craigslist, however from all I've read, they're fairly decent transmissions if you don't abuse them. For the power you're making, I'd say they're a little fragile for your application. I'm putting mine behind a 355 with an RV cam, Q-Jet, headers and Z28 valve springs (everything else is stock). Should be right on the brink of an NV3500s strength with that setup. I don't plan on abusing the truck though (burnouts, launches etc), so I don't think I'll break anything.
If you've got questions, let me know!
Gumby'sC20 is offline   Reply With Quote
Old 05-12-2013, 10:52 PM   #9
sir_talk_alot
Why would i want an automatic. And no i live way out in the country. If i put a 5spd in my short bed it would be for playing and autocross. This 5spd would be better to swap in a c20 for when i decide to go driving up to north arkansas with an atv in the bed and parts running.
-Mike-
Old 05-13-2013, 10:33 AM   #10
BlackedOut67shorty
BlackedOut67shorty's Avatar
The stock five speed will not last under abuse... Spend the extra coin and get a tremic five or six speed
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
