05-11-2013, 02:10 PM | #1 |
Body mount question poly squeaks!
I have my 69 gmc 3/4 ton w 396 custom camper. I put new poly mounts and they squeak like a gardners trucks! Should I replace again with rubber or???
05-11-2013, 02:32 PM | #2 |
Re: Body mount question poly squeaks!
Some people grease poly bushings to stop squeaks. I used anti-seize but I didn't do any research.
05-11-2013, 02:50 PM | #3 | ||
"I ain't nobody, dork."
That's the main reason I don't use poly body mounts.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-11-2013, 03:12 PM | #4 |
http://aqualubeky.com/grease/
I used this when I did the Poly suspension on my 4Runner almost a decade ago, still no squeaks and it's my offroad toy. This is what we use in the ROV industry as well, works great. I'd just pull the mounts off and apply liberally then reassembly and forget about them. http://www.marinesan.com/Aqua_Shield_Grease_s/239.htm is also a comparable product. News to me about this replacing Aqualube but makes since now that I think about the last order I placed at work.
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
05-11-2013, 03:36 PM | #5 |
Some people go around and drill a hole in the side of the bushing then add a zerk fitting.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-11-2013, 04:12 PM | #6 |
one thing to remember the rubber mounts worked many years with no noise. why change a good thing
