driveshaft removal
Had questions regarding removing my driveshaft when pulling the engine/transmission:
Everything is unhooked except the motor mounts What are the steps for removing the driveshaft so I can attach the cherry picker to the plate on the manifold and lift the motor and transmission out together? First time doing this so I figure id ask for the instructions.thanks!!! Posted via Mobile Device |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: driveshaft removal
Unbolt the rear u joint from the rearend. It will be held down with four bolts.
You're gonna want to stick a plug or spare yoke in the back of the trans when you yank it or you're gonna go all Exxon Valdez underneath the truck. Posted via Mobile Device |
Scrapper 1
my hole Idea is to drain all fluid from engine and trans cus it makes one hell of a mess,I'm pulling the 1971 350 eng and th 350 trans as the same time
Unbolted the 4 bolts of the u joints. Hmmm there is no play/slack or movement with them out.
Maybe im not doing something right Posted via Mobile Device |
The Niner
![]() Join Date: Nov 2010
Stick a small prybar or screwdriver in between the yolk and u-joint and GENTLY pry them apart.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
Thanks for the tips, im heading back out there :-P
i've never found a need to remove the driveshaft when removing engine and tranny
i just move the engine tranyy foward about 6' and the yolk comes out of tranny// i put beggie over tranny tailshaft and duct tape it to minamize the patina i allow to buildup on the floor
Not sure why, thought I needed to disconnect the driveshaft to get the yoke out of the tranny
Hmmm, the back of the driveshaft that goes to the rear axle is down, However there isnt enough slack to push the front part of the driveshaft back in order for the front yoke to slide out of the rear of the transmission. I must be doin something wrong. I am not getting any play in the middle where that drive shaft loop is welded into place. Posted via Mobile Device |
use engine crane lift engine and tranny and slide them foward as a unit yoke slips right out
a good reason why driveshaft aint goin nowhere is somebody didnt tell you to unbolt the carrier bearing
Thanks cdowns.
Ive gotta drill out the plate I bought that bolts to the stock manifold.holes dont line up .do the bolts in the stock intake that had a 2 barrel just unthread or are they studs? Theyre so dirty I cant tell. I have some new grade 8 bolts to use with the engine hoist plate just to be safe. Posted via Mobile Device Last edited by draggin49; 05-11-2013 at 09:22 PM. |
Sounds like you might have a 2 piece drive shaft... to get the shaft out you will have to unbolt the center carrier.
But like some said, with a slip yoke tail shaft you will not have to remove the shaft at all, just unbolt the trans from the cross-member and start pulling Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
Cluster King
![]() Join Date: Nov 2012
That will be all good now. Are you going to put an engine/transmission back in this truck?
It will not be so easy navigating the yoke into the back of the trans while setting the engine/trans back in the hole. Even with help it is not fun. Do yourself a favor and pull the drive shaft now and drain the fluid instead of making a mess all over the floor to lay in. A little extra time now, saves a big hassle later. That is my input on the situation. |
#13 |
Yeah its a 2 piece drive shaft, which ive never removed before so I was kinda lost. This is the original 307/manual 3 speed transmission on the column
I found this all original 48, 000 mile truck , belonged to an old neighbor. ![]() It had been sitting for 10+ years. He only used it for work, then switched to a van to carry more tools.Its pretty filthy under the hood ![]() .gonna degrease it all, repaint the frame, firewall, core support, all new hoses , belts, accessories etc Posted via Mobile Device |
#14 |
the boat guy
2 bolts should remove the carrier bearing.
Before you put the shaft back in have a professional at a driveline shop check it out. Way too many little things can go unnoticed by someone who doesn't work on driveshafts all day. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
