Old 05-11-2013, 06:31 PM   #1
kev2809
low n' slo
kev2809's Avatar
Raised gas tank
Wasnt really sure where this should go, but i figured the bagged guys would have experience with this. i moved my tank up above the frame and on 1" spacers, now obviously my tank filler doesnt line up. i cut those tabs off so that i could slide the hose on more of the filler tubes, so in this pic the filler neck and tank neck are actually about 1-2" apart, so the actual hose being "used" isnt as long as it looks. would mounting the hose like this (the angle of it really) cause any fill problems...or back flow?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-11-2013, 08:49 PM   #2
jmedero
jmedero's Avatar
Re: Raised gas tank
Yea Kevin I don't see that working very good man. If you must fill it from the outside of the truck then raise your filler hole. Hogan hot rods makes some really nice ones. If not then you can fill it from within your truck when you build the rear floor.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 05-11-2013, 08:53 PM   #3
jmedero
jmedero's Avatar
Re: Raised gas tank
http://www.haganauto.com/category_s/11.htm
Check those out man. Price isn't too bad either.
Old 05-11-2013, 08:55 PM   #4
jmedero
jmedero's Avatar
Re: Raised gas tank
Old 05-11-2013, 08:56 PM   #5
jmedero
jmedero's Avatar
Re: Raised gas tank
They have the rear tube at angles as well.
Old 05-11-2013, 09:53 PM   #6
kev2809
low n' slo
kev2809's Avatar
Re: Raised gas tank
those are nice! i was hoping to try and use the stock filler though ...is it because the angle?
i might just cut one off of a 99-06 it i have to...i like the stock cap better though
-_--_--_ _________
Old 05-11-2013, 10:46 PM   #7
Ziegelsteinfaust
Re: Raised gas tank
As for gas fillers look up boating supplies. They have some nice designs, and a few different angles to choose from.
I thought about putting a pair on my bed rail so I can fill it up from either end. That is when I do my blazer tank install.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-12-2013, 12:32 AM   #8
andrewmp6
Re: Raised gas tank
If you want something tho hide http://www.yogisinc.com/index.cfm/pa...d/prd13679.htm
andrewmp6 is offline   Reply With Quote
Old 05-12-2013, 06:55 AM   #9
wraprail
wraprail's Avatar
Re: Raised gas tank
The first thing you need to do, before anything else is raise the filler location.
Fuel aint gona flow up hill very well. (the angle of it)
wraprail is offline   Reply With Quote
Old 05-31-2013, 03:15 PM   #10
Bud1300
Bud1300's Avatar
Re: Raised gas tank
Doing the same thing, just got my new tank in this week. Glad that I am a few steps behide you your R/D is saving me a lot of time. Thanks
Bud1300 is offline   Reply With Quote
Old 06-02-2013, 10:04 PM   #11
kev2809
low n' slo
kev2809's Avatar
Re: Raised gas tank
Heres what i ended up with....The hole to the actual tank is inline, but the bend the metal filler still makes it an angle. It fills fine, but i just dont like the bend
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
-_--_--_ _________
Old 06-02-2013, 10:06 PM   #12
kev2809
low n' slo
kev2809's Avatar
Re: Raised gas tank
Not as cool as that pop up cap..i wouldve loved to do that one. For some reason i like the look of the stock cap, so i chose to move it up a few inches and forward about an inch.
-_--_--_ _________
Old 06-08-2013, 01:54 PM   #13
wraprail
wraprail's Avatar
Re: Raised gas tank
Looks great.
Hopefully will fill without issue.
