Old 05-12-2013, 01:08 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
Just got my rocklights installed
So I just installed some rocklights on the blazer, should work great for some nighttime wheeling and more likely repairs
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 05-12-2013, 01:54 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Just got my rocklights installed
Looks like they should be very effective! What lights did you use, and how many? Kinda looks like two.... one front & one rear.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 05-12-2013, 02:45 PM   #3
bigbadchev72
People know me
I have 4 of the round rubber tractor lights wired through a relay. I have 2 mounted on the front crossmember under the engine pulleys and one on each framerail pointing to the rear tires
Old 05-14-2013, 06:03 PM   #4
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
If your weren’t trying to run down those poor little jack-rabbits you wouldn’t need the lights for pulling the critters out of your driveline(s)
They look great
johnnyclack is offline   Reply With Quote
Old 05-16-2013, 04:08 PM   #5
eric67m
eric67m's Avatar
I do not mean to hijack the thread but,
How do you like your drive line E brake? Does it hold well on hills? What did you use for your lever and cable?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 05-28-2013, 03:05 PM   #6
willett
Another Day, Another Dollar
willett's Avatar
sweet! Im planning on doing the same on my k20
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
