Old 05-12-2013, 01:42 PM   #1
Truck Guy99
"New" bed not lining up?
I have a square body pickup bed trailer that had a horribly rusted out floor and bed side. I have no idea what year it was but definitely a square body. I found out only 3 bolts were holding it in. I took it off and I bought another square body bed for 120 bucks. I put it on and only 4 of the bolts lined up. 2 on the front, two on the rear. Why won't the others?
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 05-12-2013, 01:52 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: "New" bed not lining up?
Bolt holes were in different places for different years, Just get a long bit and drill new holes through the frame. I doubt it is going anywhere with 4 bolts in anyways.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 05-12-2013, 02:11 PM   #3
Truck Guy99
If I re-drill the holes in the frame to line up with the holes, it will not have any metal on it left. It's only off by about a quarter of an inch. Can I drill the bed floor and crossmember?
Old 05-12-2013, 03:28 PM   #4
ont_guy_38
ont_guy_38's Avatar
Ya you can drill the box and cross-member, just watch when you tighten them down as the original box floor holes have a crush sleeve in them.
1985 C10
2004 Avalanche
Old 05-12-2013, 03:45 PM   #5
Truck Guy99
cool, thanks
Old 05-12-2013, 11:34 PM   #6
kevinr1970
? Are these meant to be "crushed"when bolting the bed down?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-12-2013, 11:41 PM   #7
dieseldawg142
dieseldawg142's Avatar
nope, there to keep the bed floor & cross brace from getting crushed when tightening down the box
dieseldawg142 is offline   Reply With Quote
Old 05-12-2013, 11:42 PM   #8
izzy_Britton
izzy_Britton's Avatar
these 'sleeves' are meant as an anti-crush mechanism. so that when you tighten the bed bolts down they do not warp the sheet metal of the bed floor.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-12-2013, 11:49 PM   #9
Truck Guy99
It's sort of like a really stiff spring. It saves the factory time. They're normally used in rear differentials. The spring effect of the buckling of the sleeve provides a pre-load greater than any force that can release it. It's basically a strong spring.
Old 05-13-2013, 06:55 AM   #10
ont_guy_38
ont_guy_38's Avatar
Ya sorry, I should have said anti-crush.
1985 C10
2004 Avalanche
