Old 05-12-2013, 02:47 PM   #1
cci
cci's Avatar
Squealing going uphill
I've had a '70 C/20 (350) for a few months and overall it runs like a top. Recently I've noticed a squealing noise - similar to a slipping belt - when I am on the gas going uphill.
I live in a higher altitude area, and descend about 500' or so heading into town. On that leg of the trip the truck sounds normal. On my return trip though, I can hear the squealing pretty loudly as I'm climbing back up. If I let off the gas, the squealing stops - but of course then I lose speed.
The belts (my first guess) look perfectly fine and are good and tight. The previous owner had the fan clutch replaced, so it looks all nice shiny sitting there. Of course I realize that shiny doesn't equal working properly.
I just don't understand the relationship between the noise and going uphill.
Thanks!
cci is offline   Reply With Quote
Old 05-12-2013, 03:31 PM   #2
truckdude239
truckdude239's Avatar
Re: Squealing going uphill
The belts slipping under load
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-12-2013, 03:36 PM   #3
cci
cci's Avatar
That was my initial guess, but they seem pretty tight and not "glazed". I'll try tightening a bit more or maybe a new belt.
Old 05-12-2013, 03:48 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I'm pretty much 100% sure it's the belt as well. Nothing else under the hood will "squeal" under load. A power steering pump going bad or alternator bearing going out will "whine", and a wicked vacuum leak will "whistle".
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-12-2013, 03:50 PM   #5
cdowns
cdowns's Avatar
power steering belts need to b alot tighter than other belts
Old 05-12-2013, 04:01 PM   #6
cci
cci's Avatar
Thanks gentlemen. I guess the simplest answer is probably it.
Old 05-12-2013, 04:50 PM   #7
68gmsee
Active Member
68gmsee's Avatar
So, did tightning help the squealing?
I was also going to say belts but you can usually simulate that by revving the engine up. Since you didn't say you could duplicate it, my guess was something in the torque converter? Just a guess though.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-12-2013, 06:08 PM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Here is how you can diagnose if you have a belt squeal. Take the belts off and drive up the same hill. If there is no squeal, then you have diagnosed your problem. I am sure that it would not be such a distance as to create an over heating issue or charging issue, correct?
Now for the very strange side to my story. I have a friend here in Mich with a 350 Chevy powered jeep. At times going up a steep hill (like in the sand dunes) we could here a noise like a belt squeal. Same thing, removed the belts but the squeal continued. Long story short. The engine had enough crank shaft end play to allow the crank to move and the front crank seal would make contact on a different area of the crank and squeal. You want to talk about a head scratcher.
Process of elimination is a good tool in this case.
TBONE1964 is offline   Reply With Quote
Old 05-12-2013, 09:24 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You may want to change the belt.Many tighten a V-belt putting more strain on the bearings of components.It will usually work for a while but if you inspect the belt and it's in the bottom of the groove,it needs replacement. A V-belt transfers torque in the area between the slash and v like this \V/.The pressure of the v being pulled into the groove is where the torque transfer takes place.If the belt bottoms,it cannot be pulled into the V enough to transfer that torque well.Hope this helps you understand so you have more info.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-12-2013, 10:14 PM   #10
72chevyk10
I built it
72chevyk10's Avatar
if you have a edelbrock (maybe other carbs?) mine squeals going uphill when the secondarys are partialy open. but if i go WOT it quiets down to just normal engine noise. to me that eliminates the belts, on my truck...
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-12-2013, 10:55 PM   #11
cci
cci's Avatar
I'll know tomorrow. Upon closer inspection, it appears that 'yes' the belts are tight. However, as I went to further snug-up the alternator belt, I discovered that the threads in the alternator mounting "ear" are almost-but-not-quite stripped. I'm sure the previous owner knew this, but he lived in a lower-altitude area and may have never experienced the issue. I'm guessing that this allowed the alternator to move the tiniest bit - just enough for the belt to slip.
Anyway, I'll fix it tomorrow and I'm betting that will be the end of it.
Thanks to all who replied.
Old 05-12-2013, 11:09 PM   #12
JointTech
JointTech's Avatar
my tranny squealed like a banshee when it slipped going from second to third.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-13-2013, 12:09 AM   #13
ItsRandy
ItsRandy's Avatar
Mine squeals when I step on the gas...but then my tires smoke. Same problem?
ItsRandy is offline   Reply With Quote
Old 05-13-2013, 12:31 AM   #14
ajsfirehawk
I just picked up a C/20 a little over 8 weeks ago and I too had a squeal, but only during acceleration. I was drivetrain speed and when I coasted or eased off the accelerator it went away. I began to suspect u-joints, I don't have a press so I took it to my mechanic. New front u-joint, sound gone. It sounded a lot like a squealing belt.
ajsfirehawk is offline   Reply With Quote
