05-12-2013, 10:13 PM | #1 |
Installing auto meter gauges
I did a 5.3/4l60e swap, and am now trying to get my auto meter gauges wired up. I have the phantom series gauges. All electronic.
Speedometer Tachometer Oil pressure Water temp And fuel (wired and actually works) lol I don't really have any experience with doing this and just kinda figured out the fuel gauge, call it dumb luck. Are there any write ups on this? Any help will be GREATLY appreciated! Thank you Posted via Mobile Device
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
05-22-2013, 07:30 PM | #2 |
Re: Installing auto meter gauges
For oil pressure & water temp, you want adapter fittings to go from the engine's metric to the senders NPT, like so http://www.speedwaymotors.com/Auto-M...ter,20928.html
Tachometer & speedo... I don't know. It's going to have something to do with your VSS, though, either raw signal or output from computer |
05-22-2013, 07:52 PM | #3 |
Truck and auto performance nut
What year is the 5.3?
My motor is a genIV...in which case many are pulling the gauge info off the can buss. Since my motor is a genIV and I run a scan gauge I wound up wiring in my gauges as if it were say a sbc, wiring water temp and oil pressure senders using the above mentioned adapters. For the speedo I went with a GPS sender (used AutoMeters), mainly because I will run different tire sizes from time to time and wanted the speedo to stay accurate. For the tach I used the genIV Painless tach adapter...just taps into the crank sensor. http://www.jegs.com/i/Painless-Perfo...ductId=1556815
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-22-2013, 08:14 PM | #4 |
meowMEOWmeowMEOW
Tach will install just like its instructions tell you to, but may require the use of a resistor on the signal line to get a readable signal. I have this in my build, or you can read http://67-72chevytrucks.com/vboard/s...d.php?t=445975 about how TR65 figured it out.
I have a few extra of these little resistor things (they come in a 5/10 pack), which I can send you if you need it. Speedo will be pretty straightforward off the VSS, but be aware in some cases you need to wire straight off the VSS and NOT off the PCM output of the signal. IIRC the autometer speedo's look for a square wave pulse to give it input, and the ECM puts out a converted sine wave signal. This may not apply to all the speedo's, but it has come up before.
05-22-2013, 08:17 PM | #5 |
See I had issues with tieing directly to the VSS it "dirty'd" up the signal to the PCM so i had erratic shifts. So I wired straight from the PCM and calibrated it and its +/-1mph from my gps.
05-22-2013, 10:12 PM | #6 |
Hated to buy this Painless setup but didn't have a tach lead in my harness and was told there isn't one to have because the gauges run off the can buss. I have heard there is and I've heard there isn't a readable tach signal to tap on genIV motors coming from the ecm.....so is there is or is there ain't?
05-22-2013, 10:20 PM | #7 |
On my 2001 PCM
The pins for the speedo and tach are: Speedometer - C2 (red connector) pin #50 Dark green/white wire Tach - C2 pin #10 white wire Posted via Mobile Device Also have to set the tach (mine is autometer) to the 4cyl mode(2 pulse). Has to do with the pulses and get ways over my head.
05-23-2013, 12:13 AM | #8 | ||
meowMEOWmeowMEOW
From what I undertand, you CAN get a tach signal off the GenIV motors. I saw some threads on doing it with the e38 pcm. You can use Pin48 which is the tach output...but the connection is "blank" on the plug, there is a pin but no wiring on the connection. You can open up the hole on the connector and add a wire. It looks like you need to change some settings in the pcm to make it output there. Take a look at this thread, it has a setup the guys used in HPT. Quote:
05-23-2013, 12:51 PM | #9 |
I tried this or something similar with my HPT and couldn't get a signal or any tach response. I didn't have the proper pin setup tho. When I saw this Painless device that connects to crank sensor and was in the middle of an order from Summit I thought what the heck...
05-26-2013, 05:53 PM | #10 |
I had to switch my autometer elec.tach from 8cyl (4pulse) to 6cyl (3pulse) to get it to work accurately....the diagram with the resistor is from jon at PSI...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
05-26-2013, 05:56 PM | #11 |
still can't get the speedo calibrated.....it's out about 30kph.
05-27-2013, 10:22 PM | #12 | |
Finally got my speedo done and calibrated I just had a duh moment and didn't strip the wire back before crimping it...lol it was a 2am thing...lol
How fast are you going while doing it? I did mine in a an empty Walmart parking lot just doing laps around the perimeter watching the GPS closely at about 20-25mph steady. And I stopped dead on 2 miles. Mine is about 1-2mph off at 60mph, and I think that's pretty good. If that still doesn't correct yours I'd send it back if possible and have autometer look at it.
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 Last edited by Jmiller022; 05-27-2013 at 10:40 PM. |
05-28-2013, 12:42 AM | #13 | |
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
05-28-2013, 04:30 AM | #14 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-28-2013, 08:27 PM | #15 | |
genIV isn't the same as genIII. got its own little digital network...making pulling an analog signal a bit different.
05-28-2013, 08:48 PM | #16 | |
05-29-2013, 03:07 AM | #17 | |
05-29-2013, 10:20 AM | #18 |
According to what I was reading on autometers website, you should be driving 3.2km or 2 miles, not 2km.
05-29-2013, 12:27 PM | #19 | |
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
05-29-2013, 05:30 PM | #20 | |
LS1 I'll try to get that info for you.....
05-29-2013, 08:17 PM | #21 |
ls1 nova.....3969
05-29-2013, 08:21 PM | #22 |
just for kicks, I ran it up to just over 4000, and it's now a lot closer...at 50km it reads about 57, but then at 80km its showing 100+kms....
05-29-2013, 10:07 PM | #23 | |
I know the instructions say 2miles or 2km, but 2km does not equal 2miles so it must be a miss print. http://www.autometer.com/download_instruction/479a.pdf When I did my 2mile run I was slightly over 8k pulses. Posted via Mobile Device
05-29-2013, 10:27 PM | #24 |
no I haven't...but I will give it a try tomorrow....I don't have either of those senders, the speedo is hooked to a wire in the PSI harness.....
05-30-2013, 12:05 AM | #25 |
It looks like you're about 25 to 30 percent off, so 25% of your 3969 is 992, so added to what you have you get 4961. That is also about the difference between 2 kilometers and 2 miles, so like Jmiller022 said, try the 2 mile calibration, you should be close to the 5000 pulse mark. Then if it isn't exact, adjust it up or down a 100 or so pulses until it's right. Hope this makes sense.
