05-12-2013, 10:17 PM | #1 |
Where to find passenger side valve cover filter
I have a 72 350 with factory setup. Do they make a new filter and/or rubber hose that goes from passengers side valve cover to carb spacer?
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
05-12-2013, 10:36 PM | #2 |
Re: Where to find passenger side valve cover filter
I believe what you are calling a filter is actually a flame arrestor. Not sure if new ones are available. Your best bet would be a junkyard or the parts forum on this site.
05-13-2013, 07:44 AM | #3 |
most autoparts stores should have what u need// the trick is finding a counter person who knows parts and how to read a book
passenger side with hose to carb base is normally a PCV valve
05-13-2013, 10:05 AM | #4 |
I believe pcv into the carb on the drivers side. Hes needing passenger side rear breather to carb spacer ( mine all have that set up.) Youll need to find an older parts store with actual books and not the almighty computer. Or here in the board
Posted via Mobile Device |
05-13-2013, 07:25 PM | #5 |
Yeh I work part time at AZ and the ole computer won't pull anything up. No old manuals around. It is some type of filter/flame arrestor. Dug through the parts bins in back too.
Does anyone reproduce the rubber hose? Posted via Mobile Device
