05-12-2013, 11:03 PM | #1 |
Has anybody put a 60-66 frame under a 58?
I have a 58 fleetside and my dad has a 66 stepside, i was wondering if anybody has put a 58 on a 60-66 frame, or would it be better to do the camaro swap?
05-13-2013, 07:13 PM | #2 |
Re: Has anybody put a 60-66 frame under a 58?
A previous owner had done this swap on the truck I now have. I don't know how easy or difficult is was. The upside is that I can take advantage of aftermarket parts meant for a '64. This one has the trailing arm/coil spring rear suspension. The frame rails above the rear axle raise up some to give me a bit more clearance but I also had to raise the bed up to allow for this.
58 Apache short fleetside ona 64 chassis: |
05-13-2013, 07:29 PM | #3 |
I thought the wheel base was wider on a 60-66 than a TF. I would go Camaro clip before going to the work to change frames.
05-13-2013, 10:01 PM | #4 | |
Elev8r Man
I would recommend going with the same since it can dropped ALOT lower if you use the front crossmember from Porterbuilt street rods. Come to think of it he has a front section that looks great and alot of people are saying that it isnt hard to put in.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
05-13-2013, 10:34 PM | #5 |
What year camaro clip should i use if i go that way?
Posted via Mobile Device |
05-13-2013, 11:11 PM | #6 |
7o-81 gen 2
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
05-15-2013, 10:28 PM | #7 |
Thanks for all the help, I guess I may go for the camaro clip now to find one around here in ky..
Also if I do go this way, would it be hard to bag the truck with this clip? |
