Old 05-13-2013, 10:14 AM   #1
remist17
remist17's Avatar
1987 Rear swap help
Need some help. I have a 1987 chevy R10 10 bolt 5 lug rear and I want to swap it out with a 1976 Chevy 12 bolt 5 lug rear out of a C10.
Can anyone tell me the U Joint spec sizes for these? I am coming up with the dimensions but not the diameter of the caps.
1987 - 1.13X1.13 2.37 x 2.37 outer
1976- 1.06x1.06 3.22X3.22 outer
I am assuming this are not interchangable and I will need a special u joint for them...
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 05-13-2013, 06:39 PM   #2
66skylarkpost
66skylarkpost's Avatar
Re: 1987 Rear swap help
there is a conversion u-joint (precision is #372, spicer is 5-3022x ) you'll need .you will also need a longer driveshaft i believe, like an inch
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 05-15-2013, 12:35 PM   #3
remist17
remist17's Avatar
hmm
that stinks. I thought these were drop ins for the 1/2 ton trucks. Thanks for letting me know.
Support the Troops.
