Old 05-13-2013, 11:09 AM   #1
Want2Run
Engine rebuild
Once the new concrete is poured in my new garage I plan on doing and engine overhaul. Id like to bore it .40 over, and put some new pistons, I figured Keith Black was a good way to go with those? and I figured 202 heads about 72cc-64cc so therefore id have about 11.5-1 compression, Harland sharp roller rockers, Comp Cams Double valve springs, Comp Cams Roller lifters, The motor now has a fairly large cam in it, (never had it out thou) should I still change the cam? and also, I will change the intake even though it is a stock aluminum intake, and all the other small things, Any suggestions or do I have a good list (brand name) to get the more horsepower I crave.
Vette 350 Dropped 85 C10, NOS Equipped.
62 Nova Wagon 355, Heidts front end, Pushing 500
1984 Cutlass Supreme 350
1999 Tahoe
1990 B2200 Mazda(gas getter)
Want2Run is offline   Reply With Quote
