Old 05-13-2013, 10:19 PM   #1
1bad396ss
Lower A-arm Shafts
I replaced the passenger with a Moog unit. I had to get another driver lower a-arm off of a fellow board member. The driver a-arm was new unused stock unit with a shaft installed unused.
Is there any reason at all to swap this one to a Moog unit as well? I figure they are pretty basic components; however, I have the other shaft as I bought it before I knew the entire arm was trashed.
1bad396ss is offline   Reply With Quote
Old 05-13-2013, 10:23 PM   #2
Wrenchbender Ret
Re: Lower A-arm Shafts
No. Use the new one as is.
Wrenchbender Ret is offline   Reply With Quote
Old 05-14-2013, 10:08 PM   #3
1bad396ss
I like that answer!
Thanks.
Old 05-14-2013, 10:15 PM   #4
ETsC10
Hand Crafted C-10
ETsC10's Avatar
ANY A-arm pivot shafts!
IMHO..use the one you got that's rebuilt but DO run it to a FE shop and
have them check the install (a good shop that knows what they're doing).
These things are finicky...you'll probably need an alignment anyway so...
This was learned from personal experience.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
