Old 05-13-2013, 10:34 PM   #1
Painter D
Painter D's Avatar
6.0 water pump pulley??
Is this water pump pulley pressed on?
I took the fan clutch assembly off , obviously there was a large nut that threaded onto the water pump , do I need that large nut to hold this pulley on?
If I do need it how can I remove it from the fan clutch assembly?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 05-13-2013, 10:53 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 6.0 water pump pulley??
It's pressed on. You'll be fine with it the way it is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-13-2013, 11:48 PM   #3
Painter D
Painter D's Avatar
Ok thanks
Got another question, Im trying to avoid using electric fans however the fan , clutch assmebly is too close to the radiator, is there another fan clutch assembly that fits closer to the motor I can use?
Old 05-14-2013, 01:58 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
maybe some sort of flexfan setup?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
