Old 05-13-2013, 10:37 PM   #1
Brockwaykid
Brockwaykid's Avatar
any fix to emblems?
I may be purchasing some emblems on ebay in about an hour, but the problem is, the tabs have been broke off, and i was wondering what the best way would be to install them on a set of fenders. I know they are diecast so wleding new pins on is not possible, but i was thinking of making new "pins" for them and attaching them with JB Weld... If that wouldnt work then i guess 3m double sided tape will have to work.. So, are there any other ways that they can be cobbed to stay on w/out double sided tape?
Jeff Shaw
2003 Chevy 2500HD LB7 Duramax
Brockwaykid is offline   Reply With Quote
Old 05-13-2013, 10:48 PM   #2
bigwheel15
bigwheel15's Avatar
Re: any fix to emblems?
Honestly, 3m double sided tape would be fine. Dont go through the trouble of trying to jb weld the tabs back on.
bigwheel15 is offline   Reply With Quote
Old 05-13-2013, 11:39 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
The tabs won't hold, don't think you could even tig them back on the metal is so bad
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-14-2013, 12:25 AM   #4
izzy_Britton
izzy_Britton's Avatar
get some GOOD double side 3M stick tape from the body shop supply store. use the kind that comes with either a red or blue backing... here we have a funny name for it and the body and paint supply stores know what we are talking about. Grape Tape. kind of has a grape koolaide smell to it.
roll it on in big sections, way larger than you need and then trim the excess off before pulling the backing off and sticking it. way easier than trying to get the thin stuff and trying to stick it neatly to the edges.
if you want to make sure the emblem is 100% where it should be you could JB weld the tabs back on to the emblem but tape the emblem to the fender using the tabs as centering and placement tabs, as mentioned above the tabs will fall off and you will lose your new emblems.
good luck.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-14-2013, 01:47 PM   #5
Brockwaykid
Izzy, we have a few rolls of the red backed 3M stuff. It'll be a challenge to cut it off so it cant be seen through the gaps in the emblem. They are sierra grande 35's. I'll figure it out when the time comes. Thanks for all your help guys!
Jeff Shaw
