![]() Join Date: Sep 2008
wtb Help need dana 44 front drum axles immediately
HELP I NEED AXLES NOW MY TRUCK IS APART AT WORK AND MY BOSS IS GOING CRAZY. THANK YOU TO EVERYONE THAT HAS HELPED BUT UNFORTUNETLY WE ARE STILL OUT OF LUCK. CHECK YOUR TUBE NUMBERS THEY ARE A SERIES OF SMALL NUMBERS PUNCHED INTO THE LONGER TUBE NEAR THE PUMPKIN. LOOK AT UNCLES POST BELOW TO SEE WHAT THEY LOOK LIKE.
I am in serious need of a set of dana 44 axles out of a drum brake unit. disc axles are too long. I have my axle at my axle guys shop and he said I need new shafts as mine have really deep grooves from the seals. the measurements are 17-1/2 & 35-1/8 30 spline - that's from the center of the u joint to the end of the shaft on the inner shafts 9-7/8 19 spline outer shaft Approx. diameter 1-1/4 all measurements are give or take a 16th of an inch. any help would be great I know that there is some one out there that has one headed for the scrapper. Last edited by bigrigpardo; 05-17-2013 at 10:56 AM. |
Re: wtb dana 44 front drum parts
Try calling D&D truck parts out in Bellport, They might have one, I know most junkyards don't keep alot of the old stuff anymore. Can your axle shafts be sleeved where the seal is?, I'll keep my eye out for ya.
I really don't want the drum to begin with but I already have all he seals and bearings for it and they were not cheap so I figured lets just do a quick simple rebuild and the axle is good for easily another hundred thousand. so at this point I just want a used set of axles to get it back on the road
Truckin' Krazy
![]() Join Date: May 2000
The set I have are also too long, they were out of a disc brake front, sorry, no help.
Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
![]() Join Date: Aug 2003
So it needs to be a drum front. 69-70? Will check when home. Think I have a 70 front.
Posted via Mobile Device |
Think I have right one but never taken axles out. Pain in rear?
not really. pull the drum take off the 6 hub bolts and pull out the wheel bearings and crap. then unbolt the backing plate and spindle bolts and axle will pull right out. should have both axles out in half hour especially if you don't care about the drum stuff.
hey uncle if you have a 1970 open knuckle drum dana 44 that is what I have so hopefully those are the axles. MUST BE 6 LUG |
Look like it?
2
yea but you know what lets try something so you don't have to tear it apart to see if its the right one. I am pretty sure its on the longer tube. there should be some small numbers punched onto the tube if those match then we know we have a winner. I will get my numbers from my axle guy in the morning. if these are the ones and they don't have grooves what do you want for the pair of shafts???
Probably 125 shipped
if they are in good shape and are definetly the ones then I think that will be ok. can you see about the tube numbers.
#13 |
These?
#14 |
my numbers are different I think mine is a 69 axle in my 70 jimmy so I don't think the numbers mean **** but a date code. any ways I still think these are the ones. can you pull the shafts and measure just to be sure and lets hope there aren't any huge grooves.
thank you so much I need this truck done in a week or two my boss is having a **** fit over the truck being apart in the parking lot. |
#15 |
Pmed u back.
#16 |
![]() Join Date: May 2003
I'm in NH and have a complete front end out of a 70, 44 drum brake set-up, with 3.73's.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#17 |
hey can you get me the tube numbers off of yours. my axle guy keep saying they have something to do with this ****
#18 |
Sorry mine are too long. Outers same but innerspring too long. Must have changed 4x4 housing in 70 just like 2wd. If u want some of other parts let me know. If u can get both axles out in 30 u need to open a shop.
![]() Posted via Mobile Device |
#19 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
67-69 should be a closed knuckle front end and the 70 is the only open knuckle drum brake front ends that I know of. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#20 |
yea that's what I thought because 71 was drum and my 69 burb had a closed knuckle pos
#21 |
TTT hey someone out there has to have one of these I am desperate I need the right size axles two weeks ago someone help me out. all you guys cutting up a truck a week let me make you some money on the **** that would be headed to the scrapper
#22 |
![]() Join Date: Jul 2009
call moser engineering 1 260 726 6682
#23 |
No way if I am going too sepnd the money for mosers then I might as well go do the disc upgrade. The truck is a work truck and won't be seening any special treatment any time soon if I know my brother
#24 |
Ttt i need help
#25 |
ttt someone must have axles maybe closed knuckle may work?
