Old 05-13-2013, 11:17 PM   #1
luckyss
Gas pedal
Forgive me in advance but I have completed a few searches and cannot find any photos.
My truck never came with a gas pedal, just the rod coming down, and I cannot figure out how to put the one I bought on. It's just a rod with a nub at the end. The pedal I bought didn't come with any hardware so I am unsure how it gets installed. Dose anyone have a photo of the back of the petal after its installed or advice on how to put one in?
Thanks!
luckyss is offline   Reply With Quote
Old 05-13-2013, 11:41 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Gas pedal
What year is the cab?
I am sure someone will post a photo soon, I use a LMC catalog a lot for a reference.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-13-2013, 11:45 PM   #3
Hawssie
Re: Gas pedal
the plastic or rubber pedal on the bottom has two round places which pop into two ball studs that should be screwed into the floor of your truck. The top of the pedal rests onto the rod your talking about. The two ball studs allow the pedal to move back and forth at the bottom thus pushing on the top rod which in turn actuates the throttle linkage to your carb. Maybe someone has a good picture.
Hawssie is offline   Reply With Quote
Old 05-14-2013, 07:26 AM   #4
luckyss
Re: Gas pedal
I have a 67 cab
Lmc doesn't show the way it attaches
Thanks for the description, just still cannot picture what your talking about. I really think I am missing something
Old 05-14-2013, 08:22 AM   #5
Daddy Brim
Daddy Brim's Avatar
Re: Gas pedal
Look at the floor of your truck. There should be two studs with round balls on top. The pedal snaps onto these balls and rest against the rod coming through the firewall. If you see two threaded holes you will need to get some ball studs.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 05-14-2013, 09:44 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: Gas pedal
If your truck is all original and hasn't been changed around it will have the small studs on the floor as mentioned above. You can buy them from vendors. Search for "Accelerator Pedal Ball Studs."
If you still need more pics let me know. I have a few.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
