05-13-2013, 11:36 PM | #1 |
6 lug disc brake conv. now wheels don't fit!!
Well after reading here and other places like the Early Classics site and placing a thread or two, about whether to use the 6 lug or 5 lug disc rotors for a brake conversion, I thought I had all the info I needed. Heck I thought I was beating a dead horse to tell the truth. I kept going round and round whether I should do the 5 or 6 lug. The 5 lug used factory and much cheaper rotors and had much better rim selection but you had to immediately buy new rims and do the rear end. I decided to go 6 lug so I didn't have to mess with the rims and tires or change the rear axles. I did this mainly because I don't have the money to buy new rims and tires right now. I mean isn't that the point of using them in the first place! Well nothing ever came up about the fact that now the factory wheels wont work! Thats a big deal when your pinching pennies! Much bigger deal to me then the rear axle work. Of course I never thought to ask either but now I am really screwed, well at least for a month or two. Live and learn!
05-13-2013, 11:49 PM | #2 |
Re: 6 lug disc brake conv. now wheels don't fit!!
Pictures and more info may help. I a set of steelies from the old drum set up and they dont work on my discs either. I have a set of 20's that work for sell if you are looking.
BTW, if you have the stock steelies for drums, they will work with wheel spacers.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
05-13-2013, 11:56 PM | #3 |
I was just venting! I feel better now! I thought about spacers( I do not like much but it could get me through a pinch) How much spacer do you think I need?
05-14-2013, 12:00 AM | #4 | |
05-14-2013, 12:03 AM | #5 |
You do not need spacers, you need 71-87 K5 or K10 wheels. They are 6 lug and they are shaped to clear disk brake calipers. Pre-71 stock steelies will not fit over the caliper due to inner wheel profile.
05-14-2013, 12:35 AM | #6 |
Hmmm, quite interesting that your wheels do not fit.
Just a few days ago in your own thread, you were warned about this problem. Just read post #6 http://67-72chevytrucks.com/vboard/s...d.php?t=578979 |
05-14-2013, 06:22 PM | #7 |
Yes sir you are correct. That is what I have on my 6 lug disc set up and they fit like a glove. You don't really have any other option unless you buy after market stuff.
05-14-2013, 06:42 PM | #8 |
Your right! I was warned! Shouldn't have been a surprised. I didn't read that last thread response carefully enough. My bad for sure. I figured do I have a 72 Blazer(thanks for the idea) sitting around waiting for resto so I will "borrow" those rims for the time being. Thanks 68 short for making me look like a fool!
05-14-2013, 07:57 PM | #9 |
Thats why I'm keeping my drums
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
05-14-2013, 08:20 PM | #10 |
I am a Referee of life.
I got $125 in a set of rallies.They wrk well but I'm on the lookout for a set of steelies 7" to put on the front and 8" rear.I figure I can run my trim rings and I would like to run some dog dish type caps.I've also seen where the interference wa very slight and some have ground just a little off a caliper to make them fit.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
05-14-2013, 08:22 PM | #11 |
Rottenwood Garage Member
You can find a set of stock 72+ steel wheels for $50 every day of the week. Find a small shop with a tire machine and a 12 pack will get them swapped over.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
05-14-2013, 08:49 PM | #12 |
It's not "just" 72+ wheels - they have to be K10 or K5 because all non-4wd 1/2 tonners switched to 5 lug in 71 and all 3/4 tonners are 8 lug. So, it's only K10/K5 wheels that have the original steelie look, fit over the calipers, and still have the correct 6 lug pattern for a pre-71 truck. They aren't impossible to find, but they are far from common. If you find a full set (of 5, don't forget you'll need a spare for the front too...) for $50 then buy them and sell them for $150. Or better yet, pm me 1st... (just kidding, I have a few, but not selling any at the moment). They are also extremely popular with the 60-66 crowd - the only wheel to use for disk swaps with 6 lug if you want a true steelie.
05-14-2013, 09:10 PM | #13 | |
67-72 parts collector,…
They are cheap! And powdercoated. http://www.vintagetrailersupply.com/..._p/vts-545.htm Quote: This great old-style 15" trailer has nubs to fit our cone (VTS-374) style hubcaps. The wheel is 6" wide and has a 3.65" pilot diameter. It does not have an offset. It is rated to 2600 pounds @ 75psi. 6 bolts on 5.5" bolt circle diameter. Black powdercoat is standard and is a true vintage look. Simple gray e-coat primer is an option if you are planning to paint them anyway. Please expect minor scratches in transit. We sell two hubcaps that fit this wheel: Our cone style (VTS-374) and our canned ham style (VTS-694)
05-14-2013, 09:34 PM | #14 | |
Posted via Mobile Device |
05-14-2013, 09:35 PM | #15 |
They may even offer a 15x6
05-14-2013, 09:48 PM | #16 |
i have done this years ago to fit a set of 8 inch wheels and it did not take much to get the clearance to make them work
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
05-15-2013, 10:11 PM | #17 | |
05-15-2013, 10:45 PM | #18 | |
05-15-2013, 10:46 PM | #19 |
I think anyone with a 6-lug truck would know they can't use 5-lug or 8-lug wheels. It goes without saying that '71-newer 4wd wheels are what they seek. Didn't mention GM either,but I think we're covered
Too bad you're so far away,Hawssie,I have some nice 6-lug wheels from disc brake 4wds.
05-21-2013, 05:53 AM | #20 |
You have two other options for 6 lug steel wheels that fit over disc brake calipers. Toyota pick-ups (excluding the Tundra) are 6 on 5.5, but have a larger diameter center hole than GM products. The other, and I think better, option are Isuzu SUVs, including the older Honda Passport. They are also 6 on 5.5 but have the correct size center hole.
05-21-2013, 05:01 PM | #21 |
Almost forgot, if you don't want to use the 70s 15x7 K10/K5 disc brake wheels, and don't like the look of the 80s 15x8 K10/K5 wheels, I know one other low buck option. M1009 CUCV Blazers had plain 15x8s that IIRC even had the lumps to accept dog-dish hubcaps. Obviously, it's got to be the M1009 Blazer, the M1008 pick-up (& variants like the M1028) all use 16" wheels with an 8 on 6.5 pattern.
05-21-2013, 10:20 PM | #22 |
The widest traditional 15" steel wheels that came on 72-91 K/10s were 6",unless you went to the wide 8" like on M1009s available on later-70s trucks.
05-25-2013, 11:38 AM | #23 |
I had the same problem.....PICO wheel in CA, cut my centers out and installed new outer shells...150.00 for the pair. and you can go with 6 7 or 8 wide....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
