05-14-2013, 01:13 AM | #1 |
Which front lower kit?
Which would you do for approx. 5" drop:
1) Front 3" lower arms with cut 1 coil springs OR 2) 3" spindles with cut 1 coil springs. |
05-14-2013, 02:06 AM | #2 |
Re: Which front lower kit?
I would never suggest drop arms for anything. Unless they are the sole lowering part they always drag when added with spindles. That and I haven't seen any quality ones
First off what do you have for wheels right now? Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-14-2013, 08:18 AM | #3 |
Option #2
John 82 Chevy Silverado 350ci/TH350 |
05-14-2013, 10:08 AM | #4 |
18" wheels. I realize the spring pocket is lowered by 3", adding springs doesn't change the position of the lower a arms to the ground.
05-14-2013, 10:35 AM | #5 |
Watch out for your cornhole !
You are correct, however it does make the spring pocket hang down below the arms. You can always spot a truck with drop arms driving down the street. You can see the two lower pockets hanging below the truck.
You can buy 3 inch DJM spindles from summit for 240 a pair delivered. Posted via Mobile Device |
05-14-2013, 10:50 AM | #6 | |
05-14-2013, 10:53 AM | #7 |
Happy to be here
Appearently you have never looked at a truck with Lowered A-Arms. The spring pocket hangs lower than the arm. Trust us old guys when we tell you, dropped spindles are your best choice.
05-14-2013, 11:01 AM | #8 |
The thing is, if your lower arms rake the ground, and they will if you drive it enough, nothing really happens. That arm is very substantial and resists damage. But the spring pockets of a dropped arm tend to get ripped off or at the least hammered back and deformed.
05-14-2013, 11:32 AM | #9 | |
I used some Belltech lowered A arms years ago, I don't remember if that was it or if I had additional drop, probably it was the lower A arms only, since I had no problems driving. As far as which to use, I think they're both the same relative to the A arms hitting the ground, except for I can see the exposed pocket having a slight issue. Spindles are cheaper then lowered A arms which is probably why they're more popular. All in all, I'll vote for spindles and springs. |
05-14-2013, 11:36 AM | #10 |
I had 2 inch drop springs and later elected for the spindles...
2004 Silverado Crewcab (Dark Spiral Gray) |
05-14-2013, 01:52 PM | #11 |
The reason they made drop control arms is because its basic fabrication that any good fab shop could do. Some of the companies didn't have big enough britches to step up and have a foundry and machine shop manufacture spindles for them so they made and manufactured a product that was within their capabilities.
05-14-2013, 05:20 PM | #12 |
so when does a company put on big boy britches and sell a combo of lower control arms for more caster and a taller drop spindle for more camber gain
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
05-14-2013, 07:50 PM | #13 | |
My trucks are trucks, I can't see any reason to have tall spindles etc. Isn't the upper arm used for castor gain? |
05-14-2013, 07:53 PM | #14 |
I was drawn towards the new lower a arms because I would get new ball joints and new bushings already installed with an easy install, but after looking at mine I don't need new bushings. I will probably get the spindles and cut 1 coil for my drop.
