05-14-2013, 11:16 AM | #1 |
72 hood insulation
How do I change the insulation strips on my 72? Originals are shot,and hood wiggles like jello
05-20-2013, 09:09 AM | #2 |
Re: 72 hood insulation
jeeze guys whats the deal? Nobody got any suggestions?
05-20-2013, 09:11 AM | #3 |
Figures.
05-20-2013, 09:14 AM | #4 |
Sorry to have bothered anyone,won't be back.
05-20-2013, 09:30 AM | #5 |
Welcome to the forum! Just remove the old and scrap off any remaining debris. Then just slide the new padding in, you may have to gently pry the opening a little, I'd use a wooden paint stirrer. If its loose use a little black 3M weather strip adhesive to hold it in place.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-20-2013, 09:33 AM | #6 |
///Relaxed Atmosphere
ive personally havent had to do this iam sure somebody on here has, be patient.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
05-20-2013, 09:37 AM | #7 |
thanks Lee, and original 71. hood shakes like jello,old insulation crumbles to the touch
05-20-2013, 11:06 AM | #8 |
Proprietor of Dale's Corner
I've never done it yet but I think Lee has it nailed. By the way Welcome to the site!!!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-20-2013, 12:47 PM | #9 |
I built it
one of the po's of my truck put strips of carpet in it. does its job so ill leave it for now
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
05-20-2013, 03:24 PM | #10 |
Project Junkie! Fishing Poor!!
We sell replacement foam pads for this. $11.95 plus the ride. I believe I have 100 sets in stock. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
05-20-2013, 05:02 PM | #11 |
I'm glad you asked the question I got two hoods to do. I'm worried that my hood will start to wrinkle down the center from flexing too much. THXS ALEX
05-20-2013, 05:11 PM | #12 |
What is the purpose of the hood insulation? There doesn't see too much to them? My hood shakes as well.
Texas - Don't Let The Size Scare You! |
05-20-2013, 05:44 PM | #13 |
It's not really insulation. It's a pad about 2 1/2 x 28 x 1/4 and is installed between the hood skin and hood bracing, dampening the vibrations of the hood.
05-20-2013, 05:48 PM | #14 |
I've never seen one of these hoods, even when new, that didn't quiver, shake or wiggle to some extent. Some are better (almost OK) than others, but by today's standards they were horrible. In 1970, 71 or 72 Ford had a commercial comparing how rigid their hoods were compared to GM's truck hoods. A guy stood in front of the truck with the hood up, grabbed it by the front corners and flexed it. He then did the same with the Ford's hood. They also had a similar comparison showing how much better their one piece (outer skin) doors were vs. GM's 2 piece doors.
05-20-2013, 07:41 PM | #15 |
The replacement pads I bought (can't remember where) were too thin and just vibrated out and got lost.
05-20-2013, 08:02 PM | #16 |
I used urethane auto glass adhesive. Ran a nice bead on each side of the hood. Fixed the oilcan on the hood. That fix was done in 1985 and still good to day!
Trueman |
05-20-2013, 09:49 PM | #17 | |
05-21-2013, 02:37 AM | #18 |
Collector of Projects
I ordered some 3M expanding foam 2 part filler.... It expands to fill the gap...
3M Item #: 051135-08463 Product Description 3M™ Flexible Foam is a soft and flexible two-part urethane material which foams in place (closed-cell foam). It is designed to replace OEM's flexible foams found on door intrusion beams, roof bows, inside body panels, pillars, and in other automotive body cavities. Expands to 10 times its original volumeto fill large cavities with a small amount of material. Can be used for OEM replacement of flexible foams to "pre-accident condition" as much as possible. |
07-09-2013, 10:59 PM | #19 |
I need to replace mine, I took it out to paint the hood, put it back in, went on a long road trip. The A/C started squeaking once I almost got where I was going, luckily I decided to take a look to see what was up, turns out that the pad strip fell out of place, on to the AC and alt belt and chewed them up and twisted them around. Caught them just in time.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
07-10-2013, 08:29 AM | #20 |
I found the older style windshield tape works best, someone mentioned carpet....It will hold moisture and promote rust. Not a hard fix use a wooden paint paddle for sure and welcome to the forum. There is not always an answer available in just a few minutes.
06-16-2017, 12:56 PM | #21 |
Has anyone installed one of the ABS Hood Insulation Kits from LMC or Brothers.
My main question is how well does it work and is it worth it. |
