Old 05-14-2013, 10:04 PM   #1
*hotrods*
*hotrods*'s Avatar
Help I lowered my 71 Cheyenne 3/5 and need help with shocks
I did a DJM front 3" coil spring drop and a DJM rear flip kit on my 71 Cheyenne. I've mounted shorted shorks on the rear but it still seems to bottom out and ride rougth. I'm sure that other's have done this and I just need a little of help. I seen were some are doing shock relocators etc. but I would rather ask before buying a bunch of crap that doesn't work!
71 SWB Cheyenne BBC (Currently building)
69 Camaro COPO Clone 427 4sp orange
69 Camaro Pro-Touring 632ci, Viper 6 speed, 13" Baer
09 G8 GT Sport grocery getter
04 GTO, Patriot Heads, LSM Roller, 42lb injectors, full length headers, 4400 Stall, 150 Shot, equals 10.40's on street!
*hotrods* is offline   Reply With Quote
Old 05-14-2013, 10:52 PM   #2
Square_78
Square_78's Avatar
Re: Help I lowered my 71 Cheyenne 3/5 and need help with shocks
Shock relocators work well and give you a little extra travel. Also helps the shock angle. In the front just use stock length shocks. They won't bottom out.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-15-2013, 11:28 AM   #3
*hotrods*
*hotrods*'s Avatar
Were's the best place to buy them?
Old 05-15-2013, 11:31 AM   #4
CC69Rat
CC69Rat's Avatar
Call Stan at Early Classics. Be sure to tell him you are a board member and he'll give you a discount.
Also, welcome to the board from TN! Awesome 69 brother! I have built several 69's myself. Real RS/Z car? Is it the one with the 632ci ??
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-15-2013, 11:35 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Did you need to do a frame notch with that rear flip kit? I am asking because I'm thinking of doing the flip kit to the rear of my leaf sprung truck.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-15-2013, 11:41 AM   #6
*hotrods*
*hotrods*'s Avatar
Thanks for the help! I just got off the phone with Stan and there relocator kits are for coils and I have leafs. No the Camaro is not a real RS/Z Car and yes it has the 632
Old 05-15-2013, 11:43 AM   #7
*hotrods*
*hotrods*'s Avatar
Gary
No I didn't have to C notch the frame
Old 05-15-2013, 11:55 AM   #8
GASoline71
GASoline71's Avatar
Thanks!
Gary
Old 05-15-2013, 12:22 PM   #9
BMERDOC
BMERDOC's Avatar
Did you trim the bump stops?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-15-2013, 12:54 PM   #10
*hotrods*
*hotrods*'s Avatar
The new kit came with new bump stops
Old 05-15-2013, 12:57 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
The key for the rear shocks on LEAF spring trucks with a flip kit,... is to try and stand up the rear shocks at a better angle.
There is no bolt on part for this as far as I know.
I have heard of some members re-drilling the upper shock mount and moving the upper shock stud to the new hole.
The other optionis to grind out the upper shock mount rivets and move the entire mount.
If you don't address the shock angle,... the shocks lay too flat, and just pivot on the mounts,... instead of compressing the shock.
Keith
Convert to disc brakes.
Old 05-15-2013, 01:20 PM   #12
CC69Rat
CC69Rat's Avatar
I missed the leaf spring part.
Something about a 600+ ci BB in a 69 Camaro pulled me in a different direction I guess.
Chad
Old 05-15-2013, 03:20 PM   #13
cdowns
cdowns's Avatar
have you taken a tape measure and seen exactly how much range of movement that your shocks have when installed?
Old 05-15-2013, 06:06 PM   #14
no_rice
subscribed... i am in need of doing something with my shocks on the back of my flip kitted leaf setup also...
random question since we are on leafs. how many would be stock on the rear of one of the half tons? mine has 4 leafs each side, but i can squat the backend just by pushing down with my arms and not even lifting myself off the ground...
no_rice is offline   Reply With Quote
Old 05-15-2013, 06:38 PM   #15
lolife99
lolife99's Avatar
With or without shocks installed?
Keith
Old 05-15-2013, 06:47 PM   #16
lolife99
lolife99's Avatar
Look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=577529
The first thing I did was relocate the shocks.
After a bit of digging a fellow member mentioned drilling out the hole directly behind the stock mounting stud and bolting on a new one.
I used the step bit to drill out the holes and a stock Monroe mounting stud that came with the new shocks.
I had to buy a replacement 5/16” nut because the ones that came with the stud didn’t thread all the way down and lock washers (which I didn’t initially use and lost one of the nuts).
Bolted up the shocks and voila, I had some suspension travel.
Keith
Old 05-15-2013, 08:25 PM   #17
no_rice
Yep, with some old shocks on. I'm sure they are pretty weak also though. And assuming they are original leafs, they have softened up a lot over the years also...
